* Grammar fixed - but QFT :thumbsup:
Hahah best.quote.edit.ever!
Stoppped by Japlink today to get my 33 looked at, they mentioned how hard it is to sell those things now though surely you got 15k for yours Zebra? not 1.5k like your post implies..the guys at Edward lees offered me 6k for mine but would prefer it without all the mods..guess i will be returning it to stock if i ever get around to trading up. Anyway Japlink told me that if i am prepared to jump up to the 34 (so want!) then i better be ready for servicing and mod costs that triple or more those of the GT-St....:unsure:
oh well..in for a penny..
  • Replies 108
Nope 1500 bucks. After many attempts to sell at like 5 or 6 k and not even a look (this was when there were still worth over 10k)
Lol at terry btw
6k is good money for a stockish 33 these days. I wouldn't pay anymore for one
I laff at guys trying to sell gtst skylines for 15k and wonder why no one comes to look at them
It's kinda sad that vn v8 commodores are worth more these days
I love my GTR...it makes me smile just looking at it in the garage :)
If you're going to track it or mod the crap out of it I'd say go for an R33 and save the money for mods.
I haven't modded my GTR and probably never will and I think that's the way I want it now because it is just enjoyable for me to drive it on normal roads. In saying that it does attract a lot of attention...
Yeah was looking last night and I think if I do upgrade it'll be an evo. Could probably get a decent one for 30k.
Or possibley an rx7 02 model could get one of those for around 25-30 too.
Maybe I can build a gtr when there a classic haha.
You won't buy a GT-R based on logic/sense, you will buy it based purely on emotions/desire.
You know you bought the right car when you park it and look back, or walk into your garage and look at it.
This happened to me two weeks after I bought my R32 GT-R. Haven't looked back since. I'll try everything to keep it.
If I sell it, next car will be R34 GT-R.
It's not worth selling a 32 GTR... Just save a touch longer and buy a 34 and have both... Win win...
but a seal + bearing kit for a 13b is under $1000, then you just need 1/4 of a brain to put it together.
will see how i go when i get my rotary. :pirate:
just watch it when their head gaskets go, can get pretty messy apparently...
:pirate:
Ditto this sentement
If your real lucky then you might find a woman that makes you feel the same way too :rofl:
Substitute bought for found and garage for bedroom
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
