agreed....very impressive time.
that's with steven richards driving. heard richards had miles in the passenger seat and did a 2:19 before pulling into the pits and kicking miles out. He then took 2 or 3 laps to put it into the 15's.
the moral of this story for me is to spend more $$$ on seat time than on mods for the car. I believe Miles himself was lapping in the 20's so there is clearly massive time to be gained with the aid of professional tuition.
Ummmm...NO. Dont know where your getting your info from but you are waaaay off. I do the suspension setup on the car and was there so i know what happened
Steve only drove the car once on thursday (1 flying lap) and once on friday (2 flying laps). Best time he did was a 2:17 with Miles in the car and leaving plenty in reserve.
Miles had already done a 17 before Richards drove the car on friday after we tweaked the shock and swaybar settings.
Miles was definitely in the car for the 2:16's he did on saturday and the 2:15 which he set on sunday. There is a video on another thread with this lap.
As for the brakes..it still needs more. Even with the water spray they were still getting long after 2 flying laps.
Congrats to Miles and CRD for building a bullet proof car and psoting such a good time. It was only beaten by three cars, all full GT3 spec race cars.
Miles car was actually driven back to Sydney on sunday after the truck that was supposed to take it didnt show!!
Edited by jonosx
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
