Hi guys.. Just a couple of quick questions...
On the front of the throttle body of the RB30 down under where the intake pipe joins there is a small pipe connection that's for the Idle air when the throttle butterfly is closed. Is that meant to have a hose hooked up to it or not? If so, where too?
And, is the AAC valve supposed to have a spring in it? I read somewhere to be careful when pulling it apart so as to not loose the spring, mine definitely did not have a spring.
And help greatly appreciated.
https://www.sau.com.au/forums/topic/382871-rb30-questions/
Don't mean to sound like a tard here but isn't it RB20, RB25 and RB26 only, or are you referring to a stoked RB26 or something.
no idea what this has to do with my questions...
I went and had a look at a mates and his has a hose coming off it but it just goes down by the engine mount so is still sucking in air.... i ended up blocking mine off till i figure out where its meant to go.
https://www.sau.com.au/forums/topic/382871-rb30-questions/#findComment-6107870
  • 3 weeks later...
hey i dont know if im meant to post questions not relating to the one above me, but it says "rb30 questions" and this is one!
on my rb30 the fan is constantly running even with revs so i can never ever hear what the engine sounds like, just one big loud fan is what im driving right now! is there a problem with it? should i just install a thermo fan? or is that just how it is?? cheers if anyone could help me!!
https://www.sau.com.au/forums/topic/382871-rb30-questions/#findComment-6140180
Hey mate... here's a pic of the throttle body showing what I am talking about, thanks.
Oh and as for the aac valve, i got one off a mate and they do have a spring.
that pipe is for coolent to run through. to help the thottlebody warm up quicker or not freeze during winter... i think
https://www.sau.com.au/forums/topic/382871-rb30-questions/#findComment-6142024
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
