Hi everyone, I've got the following bits for sale.
Update: PRICE DROP!
1) 1 x 'new' APEXi 90mm AFM - *SOLD*
thnx Minh :rofl:
2) 1 x R32 GTS-T 4-pot front calipers & discs - $300
3) 1 x Brand New NISMO GT-PRO 2-way mechanical LSD - $1850
The same LSD as used by Nomura Ken in the Option videos for drifting. Suitable for circuit and drag too.
In response to many enquiries, this full kit includes new bearings and seals, high tensile bolts, new side shafts, new gasket, NISMO veruspeed LSD oil, hence the extra cost over other brands and NISMO's own GT LSD which only include the LSD centre. Also, the GT-Pro LSD is adjustable - 3 initial torque settings, easy to set. Some of the cheaper LSDs are NOT adjustable.
4) 1 x Brand New in box, Garett GT28 Ball Bearing Turbo - $1600
turbo plans changed and it's just sitting around now.
Spec's:- (copied and pasted from GCG website)
0.64a/r Turbine Housing (5 bolt outlet)
0.60a/r Compressor Housing (TB03)
Watercooler Centre
60 Trim Compressor Wheel
31 lbs/min Comp Flow Max.
62 Trim Turbine Wheel
Integral Wastegate 7psi
T25 Flange
320hp @ 1 bar
Prefer Sydney buyer, but can ship interstate. Interstate buyers are welcome to get someone in Sydney to inspect the stuff/arrange collection & shipping if that is preferred.
Pics - see posts below!
Can PM me or e-mail me at [email protected] if you're interested in taking this stuff off my hands :(
KJ
PMs replied to, and mchaplin check PM..
more pics when I'm free..
btw, the NISMO GT-Pro LSD is not just the LSD centre, it's a full kit. Comes with gasket, LSD oil, two brand new thingys which you connect the driveshafts to (forgot what its called!), high tensile bolts for the LSD centre and (what looks to me like) seals & bearings.
pics of the Nismo gt lsd kit would be good..thanks
it's a T25 flange turbo, to get it to fit onto a RB25 you'd need to change your dump pipe and make an adapter for it to sit on the manifold I think. More suited to S13/S14/S15/180SX with SR20DET or maybe 2 of these on a GT-R.
KJ
NISMO GT-Pro 2-way LSD kit.
Excuse my ignorance.....but will this kit suit the rear diff of a R33 GTR v-spec???
Beside removing the HICAS (rear steer) can anyone clarify the way to modify this department of a GTR....2-way rear, 1.5 way front or other???
Also can anyone give me information about higher ratio gears for the GTR....don't need the 300+ km speed, would rather get to speed quicker and reduce spool-up time for turbo's???
[email protected]
(07) 4069 8449
I think there is a nismo LSD kit for a GTR, but the one I have does not suit your car, sorry.. the shop I bought this kit from may be able to supply you tho, can ask for u if u want?
my LSD for sale suits: silvias, R32 GTST, R33 GTST, R34 GTT, A31 Cefiro and Z32 300ZX.
Z32 is good up to 500 something PS, then runs out of tuning resolution. The Q45 sized APEXi will give you better tuning resolution for high horsepower use, e.g. a big single turbo for drag on a RB25/RB26.
    • Stock R33 except for suspension, tyres, brakes, and seats is a great ride. Get that power up around the 200mark, and it's great and reliable.
    • Here's the funny thing, my EV isn't that much heavier than its petrol variant. (1773 vs 1510). An R32 GTR is 1430... AND it puts all of the weight in the lowest location. So that's taking some higher up weight, and getting it lower, and all added weight lower. That gives a really nice low CG, and means it doesn't body roll that bad too... The one I'm driving is a Kona, and for a soccer mum SUV on cheapo tyres (not my choice), she'll hold the road surprisingly well. The only part that you've got to be aware of for cornering, is that at 80kmh it will still break into wheel spin, and if you lift off, regen breaking hits in hard. Hence in sports mode, I have regen breaking dialled back to its lightest setting without being off, other wise it's really jerky to drive if you want to roll out of the power a little.
    • There was a few times that 150m marker nearly got to exit the chat 😛
    • Well, just go buy some handbrake cables. S14, S13, A31 (? Maybe not - I suspect they have R chassis brakes), whatever you can get your hands on. And throw them at the car and see what sticks. Worst case, it is not impossible to get brake cables made. They just need the appropriate termination swaged on.
