Hey all,
My first time selling something here so please be gentle. Just got some work completed on the old 200sx and came out more than I was hoping to spend, now that I'm strapped I've got to get rid of some of these excess items that I don't have a use for anymore.
As such pickup is highly preferred just to get things moving quicker. I live in Frankston (3199) and work in Highett (3190). Can meetup for pickup or organise shipping if preffered.
1. S15 200sx JDM A-Pillar with gauge holder.
As per this - JDM A-Pillar listed on JustJap
Was installed on the car previously holding the below Defi Gauge, looked good. Hasn't been on the car since I've owned it though. In great condition, always stored in plastic bag. No sigs of wear.
Price: $120
2. GKTech Adjustable Cam Gears (pair)
As per here - Link to Cam Gears on GKTech website
Bought these to replace rattliing VCT however decided to stick with VCT and bought replacement. Only ~4 weeks old, brand new in box. Paid $200 for these, which have since been reduced to clear @ GKTech... so I can't return them.
Price $80
3. GKTech SR20DET rocker arm stoppers
Link - Rocker arm stoppers listed on GKTech website
Apparently my car already had these fitted. These are brand new still in bubble wrap, never used.
Price: $30
3. Defi BF Series Boost Gauge - 60mm Blue
Model - DF04305
Link - As listed on Nengun
As above with the A-Pillar I've never had this installed since I had the car. In as new condition, no marks.
Price: $180
4. Defi Controller
Link - As listed on FR Sport
Price: $180
5. BBS 17" Wheels sprayed satin black.
Nice looking wheels, I bought the car with some Works 18's so these are now unneeded.
Will grab some more size and tyre info on these in the next day or two when I can get to my mates house where these are currently stored.
Pretty sure two of the tyres are roadworthy and two are not.
Price: $300
Pics of the wheels on the car.
Edited by MaximuSmurf
Location is in the opening post, I work in Highett, Victoria and live in Frankston, Victoria. Happy to meet up somewhere thats not too far.
Just got wheel info
17 x 8 - ET38
These came of my 200sx so they fit that fine. Also the tyres are Sumotomo HTRZ II 235/45 and I think 215/45
Sorry guys but after a few mates advised the wheels were too cheap and checking around other forums and ebay I will be adjusting the price. They are now $500. Apologies again, don't mean to be a tool about it I just didn't know what they were worth. Will reply this info to all received PM's. OP Updated.
To the admins: I had a read through the rules now and I understand this is not the place for auctions. Apologies again about the price change. Nothing else on the post will be modified again.
HAHAHA Damnit! I was willing to drive the 1,000kms to come pick them up at that price!! GL with sale :)
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
