Just wondering if anyone has been defrauded and went down the path of using a Private Investigator to track down the fraudster as NSW & VIC Police seem uninterested.
Will probably go halvies with the other guy that got defrauded a we have previously discussed.
If so, did you get the results you wanted?
Approximate Costs associated?
Related thread:
http://www.skylinesaustralia.com/forums/topic/380409-hks-t51r-kai-turbo-kit-suits-rb26/
Thanks.
https://www.sau.com.au/forums/topic/382976-private-investigators/
sh*t dude that sux!
hope you get it sorted out & your money back asap. i wouldn't buy anything off anyone who's just signed up in the last month with minimal posts & no trader rating (apart from what you left him which was a postive rating btw lol).
sh*t dude that sux!
Lol yea, noticed that but cant change it ffs...
My old man is an ex det. Sgt (worked homicide and other major crime areas, worked the cross when it was actually interesting) and now he's retired has done P.I work. If you PM me I'll get in touch with him. 90% sure he has probably let his licence lapse but he would know who is decent around Sydney.
My Girlfriends Uncle is a PI in melbourne.
may be able to do something.
But I doubt old mate would put up his real suburb.
I would keep ringing the police...remember who you spoke to and keep hassling them...let them know you really want help...even go down to the station and try and speak with him/her
Bad luck man , I personally never would buy without being able to pick up for items over $300+
Specially over 2k+ man ....
Police are only there to makes things worse not help us.
Not wrong about police...
PM Sent
I looked up the BSB and it states account is from Blackburn in VIC, although i got another address in St Albans which is 45mins away...
Ive tried police heaps and they hardly want a bar of it...
If your uncle can help tell me what information he requires and ill organise it, were up to 3 SAUer now that have been scammed by the same fellow.
Sav,
I have removed the incorrect feedback you left him, please re-add your feedback as soon as possible.
Cheers.
Thanks, Done.
Ill get the information you requested asap, my work is not allowing me a life atm which makes it hard...
sale was under 5grand which is why the police are uninterested.... sorry to hear about your loss though mate.
I think to get your PI qualification you just have to do a tafe course, exgirlfriend was doing it....
Goodluck though mate.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
