hi people i have some crap for sale will up load pics soon need it gone.
Rb20 inlet plenum and runners $100
GTR injectors cleaned up and and flow beautifully. $300
Rb20 awd rebuild engine with oversize 20thou pistons has done 20000k'ms $600 will also bolt straight to rb20 rwd sump no mod needed.
R32 gtr gearbox casing from front to rear with transfer case housing, no internals. $100
Rb20 cams $100
rb20 springs valves and retainers. $150 GREAT CONDITION
gtr transfer internals $200
I have a spare r32 gtr gear set thats need a new gear has small chipp in one tooth and 2 synchro clip may sell if right price is offered.
r33 front right hand caliper $100
r32 front left hand caliper $100
r32 front pair of brake calipers and rotors from awd may fit gtst $250
r32 pro chip equipped ecu for gtr injectors $180
working alpine head unit $100
z32 read brake caliper pair $200
also have a brand new mazda 626 turbo, mx6 turbo and tx5 turbo rebuild kit with new hypertec pistons , timing belt tensioner pullies, vrs kit, hydraulic lifters, bearings water pump, piston rings for $900 can also supply crank and block with this free of charge un machined
Mx6 turbo, tx5 turbo or 626 turbo 16 inch mags with Perfect tyres on them all 95% one mag needs painting from being repaired $300
https://www.sau.com.au/forums/topic/383041-rb-crap-fs/
  • 2 months later...
  • 4 months later...
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
