hey guys im in the middle of engineering my car. i have a 3" turbo back with a highflow cat and 1 muffler/resinator i need a noise test i dont think its to noisy however i want to make sure whats the best quick fix to quieten a exhaust
https://www.sau.com.au/forums/topic/383047-quietening-exhaust-for-db-test/
yeah i thought of steel wool but what worries me is it might spit the tip as i wouldnt put it before muffler as if it moves it will get stuck in muffler cause i want to remove it after test
I was advised to use metal flyscreen gauze.
Unbolt some exhaust maybe behind the cat, bundle it up inside and bolt it in place and use a little exhaust putty goo stuff to hide it.
Don't flog it hard and remove it when your done.
Haven't tried it but it's so crazy, it might just work.
ill just use the baffle plate i used a quick db tester on my iphone about a 1 meter away and revved it to 4500rpm and it reached 102db but i dont know how accurate the db tester would be but it gives me a rough idea
I have a silencer piece for a 3" pipe that should fit if you're keen, it makes your car quite as can be.
It just slides in and can bolt on of required I've given it some tests and doesn't come loose easily of your car has an offbeat to its idle it will really pick up on that though.
Edited by MACR34
FYI, I had to put a baffled flange in before AND after my cat as well as a silencer in my cannon muffler to get over the pits.
That was on my Legnum with 2.5"/2.75" front pipes into a 3" catback, no resonators etc. Granted the 6A13TT was louder then my old RB25DET NEO but it still took quite a bitb to shut it up.
Hmmm with the NEO it made it so quite that when giving it some you didn't hear the exhaust almost at all and all you could hear was the engine.
I don't know if it's just my car because of its setup still being 90% stock but it's super quite you barely hear it idle.
bitb to shut it up.
Hopefully a baffle plate should work on mine if not I'll put a silencer in the tip as mine is a dumpy not a cannon
My R34 just had an X-Force 3" stainless system but was pretty angry IMO.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
