hey guys im in the middle of engineering my car. i have a 3" turbo back with a highflow cat and 1 muffler/resinator i need a noise test i dont think its to noisy however i want to make sure whats the best quick fix to quieten a exhaust
https://www.sau.com.au/forums/topic/383047-quietening-exhaust-for-db-test/
yeah i thought of steel wool but what worries me is it might spit the tip as i wouldnt put it before muffler as if it moves it will get stuck in muffler cause i want to remove it after test
I was advised to use metal flyscreen gauze.
Unbolt some exhaust maybe behind the cat, bundle it up inside and bolt it in place and use a little exhaust putty goo stuff to hide it.
Don't flog it hard and remove it when your done.
Haven't tried it but it's so crazy, it might just work.
ill just use the baffle plate i used a quick db tester on my iphone about a 1 meter away and revved it to 4500rpm and it reached 102db but i dont know how accurate the db tester would be but it gives me a rough idea
I have a silencer piece for a 3" pipe that should fit if you're keen, it makes your car quite as can be.
It just slides in and can bolt on of required I've given it some tests and doesn't come loose easily of your car has an offbeat to its idle it will really pick up on that though.
Edited by MACR34
FYI, I had to put a baffled flange in before AND after my cat as well as a silencer in my cannon muffler to get over the pits.
That was on my Legnum with 2.5"/2.75" front pipes into a 3" catback, no resonators etc. Granted the 6A13TT was louder then my old RB25DET NEO but it still took quite a bitb to shut it up.
Hmmm with the NEO it made it so quite that when giving it some you didn't hear the exhaust almost at all and all you could hear was the engine.
I don't know if it's just my car because of its setup still being 90% stock but it's super quite you barely hear it idle.
bitb to shut it up.
Hopefully a baffle plate should work on mine if not I'll put a silencer in the tip as mine is a dumpy not a cannon
My R34 just had an X-Force 3" stainless system but was pretty angry IMO.
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
