anyone know which fuse is for the the headlights on the drivers side front?
i seem to have blown a fuse (i think & hope) where ive lost all internal lights which are connected to my lights on/off switch. i think ive lost tail lights too.
anyone able to help me out here?
https://www.sau.com.au/forums/topic/38305-which-fuse-is-which/
No idea but you can just start pulling fuses and checking them 1 by 1.
Check the main box in the engine bay first and then start checking the one in the passenger foot well. If theres a blown fuse you will definately find it this way.
yea i found/ was given a copy on this forum a while ago just have ta find it there it is now how the bguk do i attack sumit to this thing ( damn im computer illiterate)
R33 Fusebox translation
Dashboard Fusebox
Left Column, top to bottom: Right Column, top to bottom
10A – Rear Wiper 10A – Shift lock
10A – Anti-stop 10A – A/T control
10A – Starter Indicator 10A – Air conditioner
10A – Room lamp 10A – Engine control
10A – Stop lamp 10A – Air bag
10A – Electrics 20A – Blower motor
10A – Engine Control 20A – Blower motor
10A – Hazard lamp 10A – Audio
15A – Fog lamp 15A – Cigarette lighter
10A – Turn signal 20A – Front wiper
10A – Meters 10A – Mirror de-fogger
10A – Electrics 20A – Rear de-fogger
Note that the engine bay fuse / relay box has a fuse key printed on the inside of the cover in english.
hey there it is hope this is what you wanted
