for those people who still run a/c and want it working again for this coming summer send me a PM!!
im a qualified sparky with an aircond ticket, can retrofit from r12 to r134a and i can come to you with all the gear!
https://www.sau.com.au/forums/topic/383063-get-you-ac-freezing-cold-for-summer/
hank is it just not working or it never got optioned with a/c?
tric we may be able to do something, is it just the condensor thats the issue? u still got the compressor attached? as for the pipes ENZED normally modify ours when needed
Now I'm going to show my real knowledge....:blush:
the motor that runs off the fan belt can go back in, but there is nothing between rad and intercooler :huh:
I do have the stuff that doesn't fit in my shed ??
does that answer any questions :cool:
Edited by tricstar
haha top explanation :whistling:
how much of a gap is there between rad and cooler?
Glad you posted this up Jimmy. My aircon hasn't been regassed and made working yet since we put the motor back in 6 months ago.
A couple of years back I took it to a A/C place and they got it going but it was only cool, not cold.
Would be great if you could have a look at it some time.
haha , not much (prob down to 80mm at the bottom )and to make matters worse there is an oil cooler taking up one side so now that only leaves half the space ??:turned:
definately a custom job :mellow: I think Jimmy will just have to have a look and see what he thinks :thumbsup:
the original core is only about 25mm but if the cooler takes up half the room then it will be a little difficult >_<
yeah I'm buggered now with oil cooler taking up half the space but even before that, the core would fit no problem but not the canister ( condenser or whatever it is ) that is connected to it..
mmmm someone who can make my gt-r A/C cooler?
depends.. everyones definition of cool is different haha, a thermometer wont lie though!
let me know if u want me to come check it out
definitely gonna keep your contact! almost every single car ive looked at has needed a regas - or so they say lol its always something more when i go get it checked :(
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
