Top Secret Imports Service Centre Grand Opening - Sunday 27Th November 11Am Onwards..
Hi All,
We all saw the great turnout from our last meet & thank you to all those who attended.. So this time round TSI would like to invite you again to celebrate the TOP SECRET IMPORTS Service Centre Grand Opening.
WHEN: Sunday 27th November 2011
TIME: From 11am
WHERE: Service Centre: Unit 2, 1-3 Carnegie Pl, Blacktown 2148
SPECIAL MENTION: We would like to thank Project D Drift School, SkylinesAustralia.com, jdmstyletuning.com, Hardtuned.net, for supporting this event.
Some points for the day:
1) Media Coverage (Fast Fours, MCM, JDMST Photographers.. etc)
2) Shuttle bus' if parking becomes an issue
3) Music and DJ's
4) Red Bull and Monster Energy Drink giveaways
5) BBQ, Gelato and Coffe
6) More giveaways
7) Cross forum invite (we hope to beat our last turnout)
8) Once again there will be a friendly Police presence (Please be respectful and follow forum meet rules *There were issues and no defects handed out at last meet, so please keep it that way)
Feedback from our last even was the lighting wasn't adequate and parking was an issue, we have taken this into account so this time we have taken care of the lot :-o
Parking should be sufficent :)
I have also put some video links below of some events we have done. Hopefully this will give you an idea of what to expect.
http://vimeo.com/28609908
http://vimeo.com/29217947
http://vimeo.com/29364600
http://vimeo.com/29176437
We at SAU.NSW wish that everything goes well for you Jack & Garry; not just on Opening Day but for ongoing servicing too. We know you have a dedicated team there at the Service Centre which reflects just how well TSI is run!
Many thanks again from SAU for how TSI sponsored the Stagea 15th Anniversary Cruise. :)
Thank you for your wishes Terry.. Will pass them onto the boys.
Might drop in for a while if I can. In any case big congrats Garry and Jack as well as the support staff at TSI. :cheers:
Assuming you guys are still keeping your premises on Forge St for the imported vehicles?
Matt
Was thinking the same Steve. Thought I might be able to drop in for a bit in the morning though. But I guess the execs might need to be up north several hours before the dinner kicks off?
Congrats Garry, Jack and all the boys at TSI on the service centre. Will try and pop past before heading for the Central Coast at about midday.
    • TBH, it sounds like the threads on the bolt are fubar in a specific section. Most likely as you've been working it back and forth it has torn threads out, as you loosen the bolt, this section enters the nut, now you're spinning a round shaft inside the nut, there's no threads here.   Use something similar to a claw on a hammer that will fit either side of the bolt head and try to apply downward force while also undoing it. The idea is to attempt to catch a thread, or just rip the f**ker out. Caution on ripping out, as it could bend/maime/mangle what the captive nut attaches to. If the captive nut is actually okay, you could do the dirty part of cutting the head off the bolt, then cut a slit in the end of the thread that's now exposed and then screw it up and into the area the captive nut is until it falls out the other side. However, this does risk the remainder of the bolt rusting over time and damaging near the captive nut and also making it rust. However, so can cutting pieces of panel work out to access this area if you don't reseal it properly.
    • Well, every piece of information on that part when you track it back to Nitto says it's for a KIT of theirs. It is also designed thicker to be stronger. And they speak about a specific harmonic balancer bolt they supply for the whole setup.
    • Techniques for removing stuck bolts are: hitting the bolt head with a hammer, heating the bolt to red hot then letting it cool and working it back and forth like you are already doing. AFAIK the idea is to try to crush whatever material is stuck between the threads (and heat also melts locktite but that's almost certainly not relevant in this case).
    • Yuh, I think it works with the Nitto gear only. I presume that you're not also using the Nitto gear? Watch the video. Compare the interface between the Nitto gear and washer (on the gear side) vs the stocker and decide if you think the Nitto gear is different from stock there.
    • Liking the new charger, battery all good (I think).   Also like how you can put it in power supply mode too. Will troubleshoot with that sometime soon.
