i was thinking about this today, what is the best way to clean you engine bay, so it kind of gets rid of that "dusty" look and look nice and clean and that, just looking for some pointers,
thanks
GTRboy,
Mate this is going to sound very stupid on my behalf, but be very careful. I read here that it would be alright to clean the engine bay using water. Unfortunatley I ended up killing my spark plugs and having to get them all changed. Now it was my mistake and I took the risk, but I certainly would hold off until someone who has successfully done it (God I make it sound like something so difficult) can give you some proper advice. Just hold back the temptation and don't jump in straight away.
-Alex
Using water depends a lot on your engine and how sealed areas are. I used to work as a car valeter and were contracted by Range Rover, Jaguar and Honda to do their cars. None of those cars had problems with water and most were under 5 years old at the time (approx 2000). The instructions we were given were to keep the engine running and used to use a compressor with de-greasor to lightly spray and a jet wash to lightly spray it off. We used to put a bag over an alarm if it had one.
Having said all that I tried cleaning my older Fords and nearly killed one of them as everything is exposed.
My advice would be if you are not sure don't do it and if possible either speak to a car valeter or watch one on the job.
Hope this helps.
when i cleaned my shitbox i,
drowned it in degreaser
blasted it senseless with a high pressure water cleaner
left it to dry.
key here, left it to dry. didnt wet the batt and kept the ignition off.
ran fine first go after that. might have even got a whole 1fwkw from the effort!! :D
but yeah, i wouldnt exactly say my method was the best....
best thing is too get an atomiser bottle(spray bottle) mixed with metho and water does great results plus the metho makes it dry quick so u dont have too use a hose .... after that i usually get the elbow grease into it with some mothers mirror glase .... comes up shiny as a mo fo
