  • Replies 77
do you think whitelines are better than king springs. i'm not really fussed about the height, but rather the stiffness. i find the back to lean alot. and i hate the way it snaps back so violently when recovering from a slide, scares the crap out of me.
That's not springs, stabiliser bars and decent shocks are the propper cure.
Everybody seems to agree that Koni sport are a good shock, and Bilsteins work well on Skylines...
The Bilsteins on my car were removed last week for a quick once over, they had been on the car for over 2.5 years, and about 70,000kms and they are still in good condition. That included about 3-4 most recent track days where it was too low and was smashing the bump stops to pieces without damaging the shock, so they are pretty durable.
I havent spoken to too many suspension places , or informed ppl that recomend Tein, Cusco, HKS, Apexi etc etc....
i got my shocks inspected by traction tyre in Rowville. They said that the gas in one of the shocks has leaked, preventing the shock from lifting at the same rate as the other one. Is this a big problem?? Is it going to adversely affect the car?? Should i get them rebuild, and how mcuh does it cost?? I heard that motorbike joints do it much cheaper.
any more help would be great.
Chef: I am guessing here, but if the shock isn't lifting at the same rate I imagine it will make the car unstable. Probably not a major concern at reasonably low speeds -- depending on the rate of the leak -- but I wouldn't go hitting a track any time soon.
I'm sure one of the experts can better answer this though...
LW.
If the shocks are stroking at different rates then i wouldnt be expecting too much from them.
But i suppose it comes back to what do you want from the car. If you want it to work 100% well into the future, then i think you have to start calling some places for rebuild prices. What were the springs like, you may be able to get some Koni Sport adjustables for about $400-450 ( thats all my mate paid for his 200SX)
i don't really want it for track. You think they are worth rebuilding?? or should i try to return them?? i got screwed. haven't got the prings checked yet, so idon't know. Are they going to be useless on my car?? I'll call a couple of places tommorow for prices of rebuilds....
:D
Chef,
I would think it would be worth your while to get in touch with someone and have them take a look at the car and see what it is really like. You sound like you have a few possible problems here. Taking the car for a quick run with someone who truly knows what they are doing will be a big help. I am in Melbourne and know people who can help if you want.
Mick.
Mick. i just bought the shocks recently and have not yet put them in. I got them checked (quick inspection) and found that the rod lifts much slower on one of them, the reason for this is that the shock is out of gas. There were no leaks from either of them. I want know i can get that shock regasses, and how much it would cost. i'm on a tight budget ( got very little on me), thats why i bought them second hand.
If you know anyone who is able to regas them, or can rebuild them cheap. It would be great. Any help would be much appreciated.
thanks
In Melbourne, Centreline Suspension
couldnt agree more SK.
Since i got my car back from Chirs and the boys @ Centreline, there has been not one problem with my car. And he's worked on a few other SAU members here in Vic too.
Great service, and he was darn cheap too IMO. I was shocked when he told me the final price. Expected it to be much more.
Chef definately take you car there. They are on Lipton Drive in Thomastown.
Chances are you'll see my car there as it gets dropped off tomorrow and will be there for the best part of a week... if you choose to go there that is.
mmm.. new rear sub-frame bushes... and a new diff mount/bush thingy.
Both are shagged to the max... the diff one isnt even there anymore lol!
I already got the good suspension on the car, just needed the bushes replaced in the rear.
And a decent alignment for a change.
What kind of price did they quote you and what did you get??
Mick, any help would be great. They are Apexi, damper adjustable shocks
i called centreline, they said that they don't know anyone who does rebuild for apexi shock. Should i be looking for a motorbike joint for it??? I'll try to take the shocks to thomastown tomorrow for them to take a look.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
