  • Replies 77
do you think whitelines are better than king springs. i'm not really fussed about the height, but rather the stiffness. i find the back to lean alot. and i hate the way it snaps back so violently when recovering from a slide, scares the crap out of me.
That's not springs, stabiliser bars and decent shocks are the propper cure.
Everybody seems to agree that Koni sport are a good shock, and Bilsteins work well on Skylines...
The Bilsteins on my car were removed last week for a quick once over, they had been on the car for over 2.5 years, and about 70,000kms and they are still in good condition. That included about 3-4 most recent track days where it was too low and was smashing the bump stops to pieces without damaging the shock, so they are pretty durable.
I havent spoken to too many suspension places , or informed ppl that recomend Tein, Cusco, HKS, Apexi etc etc....
i got my shocks inspected by traction tyre in Rowville. They said that the gas in one of the shocks has leaked, preventing the shock from lifting at the same rate as the other one. Is this a big problem?? Is it going to adversely affect the car?? Should i get them rebuild, and how mcuh does it cost?? I heard that motorbike joints do it much cheaper.
any more help would be great.
Chef: I am guessing here, but if the shock isn't lifting at the same rate I imagine it will make the car unstable. Probably not a major concern at reasonably low speeds -- depending on the rate of the leak -- but I wouldn't go hitting a track any time soon.
I'm sure one of the experts can better answer this though...
LW.
If the shocks are stroking at different rates then i wouldnt be expecting too much from them.
But i suppose it comes back to what do you want from the car. If you want it to work 100% well into the future, then i think you have to start calling some places for rebuild prices. What were the springs like, you may be able to get some Koni Sport adjustables for about $400-450 ( thats all my mate paid for his 200SX)
i don't really want it for track. You think they are worth rebuilding?? or should i try to return them?? i got screwed. haven't got the prings checked yet, so idon't know. Are they going to be useless on my car?? I'll call a couple of places tommorow for prices of rebuilds....
:D
Chef,
I would think it would be worth your while to get in touch with someone and have them take a look at the car and see what it is really like. You sound like you have a few possible problems here. Taking the car for a quick run with someone who truly knows what they are doing will be a big help. I am in Melbourne and know people who can help if you want.
Mick.
Mick. i just bought the shocks recently and have not yet put them in. I got them checked (quick inspection) and found that the rod lifts much slower on one of them, the reason for this is that the shock is out of gas. There were no leaks from either of them. I want know i can get that shock regasses, and how much it would cost. i'm on a tight budget ( got very little on me), thats why i bought them second hand.
If you know anyone who is able to regas them, or can rebuild them cheap. It would be great. Any help would be much appreciated.
thanks
In Melbourne, Centreline Suspension
couldnt agree more SK.
Since i got my car back from Chirs and the boys @ Centreline, there has been not one problem with my car. And he's worked on a few other SAU members here in Vic too.
Great service, and he was darn cheap too IMO. I was shocked when he told me the final price. Expected it to be much more.
Chef definately take you car there. They are on Lipton Drive in Thomastown.
Chances are you'll see my car there as it gets dropped off tomorrow and will be there for the best part of a week... if you choose to go there that is.
mmm.. new rear sub-frame bushes... and a new diff mount/bush thingy.
Both are shagged to the max... the diff one isnt even there anymore lol!
I already got the good suspension on the car, just needed the bushes replaced in the rear.
And a decent alignment for a change.
What kind of price did they quote you and what did you get??
Mick, any help would be great. They are Apexi, damper adjustable shocks
i called centreline, they said that they don't know anyone who does rebuild for apexi shock. Should i be looking for a motorbike joint for it??? I'll try to take the shocks to thomastown tomorrow for them to take a look.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
