Evening all,
I have a problem with my R34 GT-T where the TCS Off and SLIP lights are lit on occasions. The time between starting the motor and the lights coming on is varies, sometimes a couple of minutes, other times it may be an hour or more.
Restarting the motor will turn those lights off for a random period again.
My totally random guess is that its a sensor somewhere playing silly buggers (hope its not the PFC). Does that seem like a reasonable?
If so, where and what should I look for?
Is there anything I can do myself to see if I can fix it like clean sensors, or remove sensor wiring plugs and clean, check sensor cables for visable damage?
Failing all that, who should I take the car to for this to be fixed? Nissan dealer, auto electrician or skyline specialist?
https://www.sau.com.au/forums/topic/383152-r34-warning-lights-tcs-off-slip/
  • 10 months later...
super common problem, as Dan said, 99% likely to be coilpacks
does the car sound different when the lights come on? sound like a WRX?
i'm guessing coilpacks, and if that's the case get Splitfires, don't waste your time with yellow jackets etc.
Just need someone to do a consult check of the error codes. But really, you're probably better off replacing the coilpacks as you'll probably have to do them sooner or later :P
Dont be fooled its not always coil packs seems the tcs is failing on a lot of R34 GTT in the past few months , mine did the tcs and tps packed it in a week later , splitfire coil packs didnt fail till the next month lol no better then all the rest didnt even get 3 yrs out of them barely driven , i swapped out my throttle body for another off a wrecked car and it fixed my tcs slip light it will also chuck up abs light when it fails , the codes didnt match the problem indicated , once a new used body was installed and battery reset it was fixed except for tweaking the tps for my car - nistune
It also disables the car when it fails no more then 2,000 rpm redline is available and that sucks bad
Edited by Carbon 34
  • 1 month later...
I may have had the same issue earlier in the year. the lights kept recurring for months!
I looked up everywhere trying to figure out what was wrong and heaps of people said it was related to the coilpacks. I took it to a tuner to let them figure it out and it turns out my coilpacks were fine (in fact, they were still in very good condition).
they said it was the throttle body, so they replaced it but the lights still came on!
after a 3 weeks of them looking at it (yes, i kept taking it back because they said they "may" have fixed it even though it wasn't), they said it turned out to be that the ecu pins had been all bent up and therefore wasn't establishing a good connection. i don't know if it's true or not, but i haven't had any issues for more than half a year now.
I hope that helps.
jay
I hope that helps.
jay
Your welcome people need new coilpacks on old cars but that isnt aways the fix!
Your error lights wont go off unless battery disconnected and ecu reset , after throttle body fix
Pins bent on ecu doubt that highly unless it was monkey'd with , most likely the plug pins in front of intake manifold , thermostat area these corrode bad so sometimes its that simple to sort out
Pretty safe to say this is a serious annoying common defect on gtt with all the failures lately
That's why you do the diagnostic, takes literally 30 seconds and you know EXACTLY what has gone wrong, instead of all this guessing bullshit. Every single computer in the R34's has a diagnostic function, all will give you the answer depending on what sub-system or sensor/actuator has failed.
I had the TCS stepper motor fail also, never limited the car in any way though.....maybe your butterfly was stuck down, making the car feel gutless?
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
