Guys,
For sale is a
  1. Use pair of Nismo blinkers - $20
  2. brand new Greddy Boost Controller Profec B Spec- II - $320
  3. 2nd hand but never used Apexi SAFC-2 super air flow converter with the plug and play harness - $240
However if you want to take it all together, I will sell it for $500+postage.
Any questions, please ask. Looking to get rid of these ASAP as I've now sold my car, so make an offer.
Cheers
Edited by TramanBaba
    • Currently at 380rwkw with 2860 -5's & b cams on e85, trying to make it have a bit more torque/usable power down low.    Ive googled the v cams and most sites say discontinued, is there anywhere you can still get them?
    • Most hardlines are available new still. But unless they're rusted to the point of needing replacement you can just zinc or cadmium plate them to keep them going for decades to come. Regarding the turbo drains it really depends. Braided lines might be better if it's a straighter path than OEM but I would not assume braided teflon lines will never leak. Teflon is a very durable material but you can still abrade, erode, or otherwise compromise its integrity. The return hoses on the bright side are not that hard to access relative to a full turbo removal so if things go wrong you can always put it back to stock. You can very easily drive yourself insane analyzing every little change, or maybe that's just me.
    • ...gearbox connector... CD06 -- solenoid A
    • Very happy with mine and I think you will be hard pressed to find someone that isn't happy after installing.  Is it the best value for money vs other mods (eg 2.8 stroker) hard to say.  If you are building an all out power motor above 1000hp+++, it's probably not for you as you will want bigger cams.
    • Cheers man, I'm almost a little bit relieved in a way. Let the trouble shooting begin!
