I work as a Despatcher, and if i were you I would not send anything Toll Ipec's way unless its insured. I have lost many thousands of dollars worth of stock through their incompetent ways.
You might find youself in a bit of a position walking down to the post office with a full exhaust don't you think?
Anyway if i were you I would send via TNT Road Express, its cheapish, reliable and they will come to you and pick it up, and also drop it off personally.
Aust Air Express are even more reliable and faster than TNT but comes at a cost.
I'll give your a rough guide as to work out costs via TNT road to major citys
First you will need to calculate Volumetric weight (cubic) here's how
Height x Width x Length / 4000 = Cubic Kg
From Melb to Syd/Can/Adel $13.60 up to 15kg add 0.34 for every Kg over 15kg
From Melb to Bris/Perth $31.45 up to 15kg add 0.95 for every Kg over 15kg
TNT - 13 11 50 you can call this number for a quote.
Insurance is avilble upto $1000 for an extra $10
Hope this helps. :P
doesent the actual weight come into it? coz i want to send my old clutch to bris and its small but real heavy
Yeah is does INASNT as most things in life its going to be worked out at whatever is going to cost more.
If the physical weight is more than the cubic weight it will be charged at the real weight of the item.
But in C34ations case its going to be really large but not that heavy so it will be worked out by the size.
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
