I work as a Despatcher, and if i were you I would not send anything Toll Ipec's way unless its insured. I have lost many thousands of dollars worth of stock through their incompetent ways.
You might find youself in a bit of a position walking down to the post office with a full exhaust don't you think?
Anyway if i were you I would send via TNT Road Express, its cheapish, reliable and they will come to you and pick it up, and also drop it off personally.
Aust Air Express are even more reliable and faster than TNT but comes at a cost.
I'll give your a rough guide as to work out costs via TNT road to major citys
First you will need to calculate Volumetric weight (cubic) here's how
Height x Width x Length / 4000 = Cubic Kg
From Melb to Syd/Can/Adel $13.60 up to 15kg add 0.34 for every Kg over 15kg
From Melb to Bris/Perth $31.45 up to 15kg add 0.95 for every Kg over 15kg
TNT - 13 11 50 you can call this number for a quote.
Insurance is avilble upto $1000 for an extra $10
Hope this helps. :P
doesent the actual weight come into it? coz i want to send my old clutch to bris and its small but real heavy
Yeah is does INASNT as most things in life its going to be worked out at whatever is going to cost more.
If the physical weight is more than the cubic weight it will be charged at the real weight of the item.
But in C34ations case its going to be really large but not that heavy so it will be worked out by the size.
    • Ohh even easier.   Go dial up 700rpm on the hand controller. Rip off the TPS plug, wait till the idle drops and then adjust the IACV screw so it's just a tad below the target on the hand controller (say 650rpm), plug the TPS back in and idle will climb back to target. Done.
    • Hey Sleepergm, I love your inlet piping, do u mind sharing who did the work, please? cheers, Ian
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
