Hey guys I have searched and noticed most people got the 5" body cat from venom I'm going to order a cat from venom but not sure what one to get I think the 5" body will be overkill as I'm still only running stock turbo but will soon be upgrading and looking at 300kw would the 4.5" body be a better bet for my application Oh my exhaust is a 3" from turbo back
https://www.sau.com.au/forums/topic/383207-45-body-venom-cat/
  • Replies 53
Just some food for thought about flow. My R33GTSt will turn the tires for about 100m in 3rd when it comes on boost at 110kph. I'm still using a stock cat.
So? Same as the people that say a 3" exhaust flows 350rwkw.
Swap it to something that flows better and then they pick up power, torque and response. 40rwkw is not uncommon when the restriction is that bad.
Less restriction = happier motor, tune and everything associated.
Just because something "makes XXXrwkw" doesn't mean it can't be better for simple changes.
I generally agree with everything you say in your post.
One of the points that I implied in my previous post is there was that the OP has a stock turbo and worrying about a 4.5 or a 5 inch cat should be way down the list. Getting one or the other is not even worth considering. Just get either. If the OP is chasing power then there are plenty of better ways to get it.
I have dyno'd a 600hp engine that with a 3 inch system. It lost power with a 4 inch system. It wasn't a turbo engine but the overkill principle is still the same.
Someone might pick up 40rwkw (maybe me when I pull my finger out and swap the cat) but it wont be the OP with his current setup.
I took a couple of guys for a drive the other day and the first thing they commented on was how quiet my car is. The next thing was how it surprised them by how well it went.
Cop bait is not always best and a loud exhaust is one of the primary thing you will get picked up for.
I picked up 2mph in the 33 just by running a cat delete pipe over the standard cat...no change in the tune, but would pull harder from 6k to 7krpm.
side note - changing from the standard dump pipe with 3" front pipe to a 3" bell mouth dump/front made no difference.
Done back to back on the same day at Heathcote
Edit - all on standard turbo
so would mine with a 2.5" emissions cat but you will find that you are building up a lot of pressure in there before the cat, mine blew out both gaskets pre cat.
That isn't a lot of difference. Sure, it is something though.
N/A & turbo are not the same by any means. Comparing the two is misleading.
And 2mph from removing a CAT is actually quite a big gain realistically for a stock turbo.
I just picked up a JJR 3" dump/front last week, are u saying it will make stuff-all difference to my set-up with stock turbo??pinch.gif (see signature below for my set-up).. Just realized I have a 4" body 3" inlet and outlet 100 cell metal cat (Lobokka brand off ebay), instead of a 5" body which people recommend, is this going to restrict my exhaust when I get 280-300rwkw down the track later???
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
