Hi All,
I've got a totally stock R33 GTS-T and recently when pulling away from the lights the car struggled to accelerate past 2k RPM.
I'll have my foot flat on the throttle (and shows and sounds like the turbo is at full boost) but the revs go very very slowly above 2RPM and there's obviously no pull - no matter what gear i'm in.
I've changed my coilpacks about a month ago and the current problem doesn't seem like a misfire as such, it feels as though my foot is only slightly down on the gas (even though it's flat!!)
Is this the sign of a faulty AFM?? I don't think there's any smoke, but there's a bit of a odd smell when I pull up - the smell could, however, just be me haha
Any advice?
https://www.sau.com.au/forums/topic/383245-engine-stuggles-above-2000-rpm/
It can be dodgy afm. 2krpm is the limp mode for the car. If it has a stock ECU stick a consult in it and see if has any issues. Do you get any engine check light? Could be many things causing this, boost leak, dodgy accelerator cable not opening the throttle, faulty afm, faulty injectors, misfire etc.
Thanks for the reply bud.
It does indeed have a stock ECU. The problem occurred once last week must seems permanent now :s
Every once in a while it shoots past 2000 RPM but 90% of the time she struggles. Very frustrating!
i had a similar problem. my stagea (r33 s2) occasionally wouldnt accelerate beyond 1500rpm. it was something to do with the fuel conservation mode the car goes into on idle - it was getting stuck in that mode! which was of course limiting fuel delivery and therefore power.
i fixed it by bypassing the dropping resistor and making the fuel pump go full pressure all the time
I did have a service last week (just changed engine oil, tranny oil and coolant) but she was ok for a day or two after that...
Also I had switched to Yellow Jacket coil packs about a month ago...
I haven't looked for any blockages as yet. Will do so tonight
Hello Dre678,
I can tell you it's not a faulty AFM as when they go bad the R33 ECU (At least in my car) won't let the car go past 4500 RPM and it's a hard jolt like hitting a rev limiter.
I would be more inclined to think it's related to boost at the moment as 2000 rpm is around when the stock turbo kicks in. Can you drive high RPM low boost? i.e. Very little throttle, Low gear. But really I know nothing more than it's not a faulty AFM.
You can try an ECU reset, it's completely harmless. (Check the forced induction quick reference guide)
Cheers
Check the throttle is opening fully when u press the pedal down.
Check TPS settings and base timing etc.
Is there any black smoke when it struggles to rev?
Check airfilter and catalytic converter
Thanks Aqeul and Jez,
I did try to keep the throttle slightly open in a low gear - it did creep past 3000 RPM but it didn't last for long as soon as the boost kicked in.
I haven't noticed any plooms of smoke when pulling away but obviously that's something I can miss.
I'll check out the cable tonight and might try the ECU reset too. I've got it booked in at a skyline shop tomorrow but obviously I'd rather solve it myself...
I don't know much about the throttle position sensor, but i'll do a search here.
Thanks again for the advice.
Wind boost down to a dead stock level by running boost pressure straight to the actuator just to test.
Google will have lots of info on the throttle position sensor, it's worth checking your throttle body. Though if it can rev to redline in neutral very quickly with WOT though I would imagine it's not throttle body problem and more of a "tune" problem.
If you reset your ECU with a paper clip like in the how to on the sticky in the forced induction section it will give you self diagnostics by flashing the check engine light slowly "x" number of times and quickly "y" number of times to give you an error code "x,y" that can help you diagnose if it's a faulty sensor.
EDIT:
Resetting ECU: http://www.skylinesaustralia.com/forums/topic/2879-resestting-ecu/page__view__findpost__p__3262978
Error Codes: http://www.skylinesaustralia.com/forums/topic/2879-resestting-ecu/page__view__findpost__p__1699249
EDIT:
Resetting ECU: http://www.skylinesa...ost__p__3262978
Error Codes: http://www.skylinesa...ost__p__1699249
Yep, in neutral there was no problem - the problem only occurred when in gear.
So I followed your advice and reset the ECU. It return a 55 code (which I read means all is ok) I went for a drive (a hard one) and it seemed to have done the trick.
I'll go for a drive tomorrow and i'll rack up plenty of km's over the weekend so here's hoping the problem has been solved! Thanks for all the advice!
  • 8 months later...
I had this problem today when I drove my car, I called my mechanic and he thinks it may have picked up bad fuel or had a blocked fuel filter. The problem seemed to go away after I put new fuel in it and cleaned the afm. I hope it's not planning on coming back!
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
