hi.all the posts and info i've read usually on say how to fit the r33 rb25de/det and rb26 heads on the rb30 but whats involved fitting the rb25de/det heads.do all oil and water lines line up.i've read the neo heads ccs' are smaller then the r33 rb25 heads.what comp ratio will it give with the stock rb30 pistons.if it bolts straight up as the rb25 with the the vct and front water gallery mods can i use the stock rb30 pistons.sorry for all the questions
https://www.sau.com.au/forums/topic/383259-rb25det-neo-head-on-a-rb30/
They have 10-12cc smaller chamber, it is pretty much the same as putting a vct head on, make sure you get the right pistons to suit or your comp will be too high for turbo
only oil line that doesn't line up is the vct feed, have it welded as grub screwing it will leak
I personally used Mahle 8.5:1 Rb30 pistons from the US. shaved the block 20thou to get a 0 deck height. The head was skimmed to make sure it was flat and using a standard nissan head gasket and to my knowledge I don't have any issues with excess comp and pulls like a freight train in it's midrange (I haven't given it a good hiding since it's only street tuned to about 5krpm)
Theres are a few differences, with the head chamber being smaller as mentioned above..
I have my head neo cc'd and each chamber came in at 53ccs, so if you used the "normal" pistons in a rb25/30 then the comp ratio would go through the roof.
I've purchased ACL RB30ET pistons with the -4.5cc dish in the piston which is just an off the shelf item. Based on my calc, with a bore of 86.5mm, 1.1m headgasket, 0 deck height (i.e. shave to block by 20thou) you get a comp ratio of 8.8:1 - which is pretty spot on in my books.
Also the VCT feed is definitely different and you have to use the drill/tap method for the oil feed at the front of the head for it to work again. Just make sure you have it grub screwed/welded to block it off as mentioned above.
Other than those two, everthing else should bolt straight up as a normal rb25 head:)
thanks for the replies guys.im busy gathering as much info as possible.starting my rb25/30 build in the new year.so if you use the stock rb30 pistons would the comp be good for a n/a motor then.one more question.can sr20 and/or vg30dett rod bolts be used as an upgrade for standard rb30 rod bolts.
If this is a budget build then i recommend to do a bit more research and save a bit more coin to do the job properly the first time, with using all the right parts
Links below, 1 is a tutorial i wrote up to give the basic understanding of engine internals
2nd is a link to the tutorial section, there is alot of useful information there other members have written up
3rd is the members project threads, look what others have done and see what ideas you can use or adapt things they've done for your intentions
http://www.skylinesaustralia.com/forums/topic/378823-engine-internals-comp-ratios-general-info/page__pid__6104330#entry6104330
http://www.skylinesaustralia.com/forums/forum/57-tutorials-diy-faq/
http://www.skylinesaustralia.com/forums/forum/190-projects-overhauls-and-build-ups/
  • 5 months later...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
