hi.all the posts and info i've read usually on say how to fit the r33 rb25de/det and rb26 heads on the rb30 but whats involved fitting the rb25de/det heads.do all oil and water lines line up.i've read the neo heads ccs' are smaller then the r33 rb25 heads.what comp ratio will it give with the stock rb30 pistons.if it bolts straight up as the rb25 with the the vct and front water gallery mods can i use the stock rb30 pistons.sorry for all the questions
https://www.sau.com.au/forums/topic/383259-rb25det-neo-head-on-a-rb30/
They have 10-12cc smaller chamber, it is pretty much the same as putting a vct head on, make sure you get the right pistons to suit or your comp will be too high for turbo
only oil line that doesn't line up is the vct feed, have it welded as grub screwing it will leak
I personally used Mahle 8.5:1 Rb30 pistons from the US. shaved the block 20thou to get a 0 deck height. The head was skimmed to make sure it was flat and using a standard nissan head gasket and to my knowledge I don't have any issues with excess comp and pulls like a freight train in it's midrange (I haven't given it a good hiding since it's only street tuned to about 5krpm)
Theres are a few differences, with the head chamber being smaller as mentioned above..
I have my head neo cc'd and each chamber came in at 53ccs, so if you used the "normal" pistons in a rb25/30 then the comp ratio would go through the roof.
I've purchased ACL RB30ET pistons with the -4.5cc dish in the piston which is just an off the shelf item. Based on my calc, with a bore of 86.5mm, 1.1m headgasket, 0 deck height (i.e. shave to block by 20thou) you get a comp ratio of 8.8:1 - which is pretty spot on in my books.
Also the VCT feed is definitely different and you have to use the drill/tap method for the oil feed at the front of the head for it to work again. Just make sure you have it grub screwed/welded to block it off as mentioned above.
Other than those two, everthing else should bolt straight up as a normal rb25 head:)
thanks for the replies guys.im busy gathering as much info as possible.starting my rb25/30 build in the new year.so if you use the stock rb30 pistons would the comp be good for a n/a motor then.one more question.can sr20 and/or vg30dett rod bolts be used as an upgrade for standard rb30 rod bolts.
If this is a budget build then i recommend to do a bit more research and save a bit more coin to do the job properly the first time, with using all the right parts
Links below, 1 is a tutorial i wrote up to give the basic understanding of engine internals
2nd is a link to the tutorial section, there is alot of useful information there other members have written up
3rd is the members project threads, look what others have done and see what ideas you can use or adapt things they've done for your intentions
http://www.skylinesaustralia.com/forums/topic/378823-engine-internals-comp-ratios-general-info/page__pid__6104330#entry6104330
http://www.skylinesaustralia.com/forums/forum/57-tutorials-diy-faq/
http://www.skylinesaustralia.com/forums/forum/190-projects-overhauls-and-build-ups/
  • 5 months later...
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
