i have an r33 rb25 and i looking for a good turbo that has plenty of low-end, good responsiveness, and pulls all the way to redline. I'm looking for 375-400 whp and am stuck between a td05h-18g and a td062-20g. which turbo suits the rb25 better and uses the stock manifold? this is my set-up for far:
-nismo 550 cc injectors
-sard fpr
-greddy fmic
-greddy intake plenum
-3" cat-back
-3" down-pipe
https://www.sau.com.au/forums/topic/38326-td05-vs-td06/
I dont think the td05-18g will get you to 400hp the td06-20g should. Mine made 339hp @ 1bar the engine has gone in to be rebuilt with forged pistons and I expect we should see 400hp at reasonable boost levels. Before I killed the engine I drove around on 1.2bar (thats how I killed it) and the difference between 1 and 1.2bar was huge in the seat of pants region... didnt get a chance to dyno it as it developed a misfire and then piston 3 and 6 ringlands went. I also think on trust's website they recommend the td06-20g for the r33 and the td05 for the sr20, i have the huge 16cm^2 exhaust housing and it makes full boost by 4300rpm if you went for a 12cm^2 it should come on a bit quicker but you might loose a bit of top end, my car pulls hard all the way to the redline (which was set at 7500) but we might take it to 8000rpm as it still pulling hard. The only problem with my car (nothing huge) is that to get the most out of it you have to pull it to the redline and then shift, any short shifting will result in dropping out of the power band and the turbo having to spool back up again. If you want more info PM me.
https://www.sau.com.au/forums/topic/38326-td05-vs-td06/#findComment-775301
Guest INASNT
do you think a td05 has the potential to dip me into the 12's? i'm really shooting for 375ish whp and want something a lot more responsive than a turbo that's going to spool at 4000 rpm.  what hks turbos compare to these size mitsu turbos? what about a gt2530?
A 2530 will give u good low down power but not much top end. Its only slightly bigger that the stocker. If u want a HKS turbo go for a 3037.
U will always have to live with a bit of lag if u want near 400rwhp.
https://www.sau.com.au/forums/topic/38326-td05-vs-td06/#findComment-775602
u dont need a big turbo to dip into the 12's. Infact from memory someone on here has done a 12 with stock turbo. Something a little bigger would easily give u the power thats needed to pounce ur car across the line for a 12 but its not just the turbo thats gonna help u reach that goal. If u got the launch, traction, gear changes right then ur looking good. TD05-18G would do a 12 in ur car, if a stocko turbo can get someone into the 12's then most turbos wil. goodluck.,
https://www.sau.com.au/forums/topic/38326-td05-vs-td06/#findComment-775670
i think i'm going to use the td06-20g with a 10cm^2 exhaust housing. i believe that this turbo would be well suited for the street and still be able to put down 350+ hp. As for 1/4 mile times; the engine is an R33 Rb25...however...the car is a 1996 240SX(lighter) so we'll have to just wait on times slips, and dyno runs.
https://www.sau.com.au/forums/topic/38326-td05-vs-td06/#findComment-785662
banzai have Td06-25G's for sale for 2300 brand new. www.banzaimotorsports.com.au
They are advertised for $2400 and Banzai rate them at 600hp. (don't think so)
Very plain compressor housing...looks like a cheap copy...Doesn't look like a Greddy Turbine and isn't plated as such. The picture of the TD05 above it, is a Greddy turbo. The two TD06 SL 20G's I have, looks the same as the Banzai picture of the TD05...except larger in size and rated at Genuine 450hp each. The quality of my TD06's is a lot higher than the Banzai 25G pictured.
Though the Greddy TD06 - 25G had an internal wastegate, not external?????
happy hunting
Phillip
https://www.sau.com.au/forums/topic/38326-td05-vs-td06/#findComment-786230
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
