yeah, its kind of like riding a rocket, you just know ist going to go hard but will also blow up eventually!!!
But for one lap it looks good.
well there were 3 458 GT3's in the top 10 at the end of the Sap 24hr this year, not bad for a car everyone seems to think won't last the 12 hours at bathurst
But what about the 4-5 DNFs~ :whistling:
I would still take a big lazy pushrod V8, flat 6 or V10/V12 over something that has to pull 9,000rpm for 24 hours. Still, was watching them at Spa a few weeks back. They are great looking things! Cant imagine the budget it would take to run one vs the Viper or Porsche
  • 3 months later...
back at it again this weekend, hours in before the ran the 458GT3 has set a new official lap record in the 12 hour a 2:06.3311 with another 4 cars under the V8 Lap record
http://www.natsoft.com.au/cgi-bin/results.cgi?26/02/2012.MOUN.R13
Edited by Whiplash
i doubt the v8's will break that record. this year is the last year they will have a chance, because under the COTF regs they will have less power, so will be lapping slower.
But they will have better suspension and handling. The GT cars peaked at around 260 - 270kph on conrod compared to the V8's knocking on 300kph. All the time is made up across the top of the mountain.
The GT cars have much better aero, but the driver reports on the COTF state that they handle a lot more like the Cup Cars
Don't forget COTF is considerably lighter than the current cars as well, and I would not be so certain about the loss of horsepower...
don't know if i'd call 100kg "considerably lighter". certainly lighter (enough to make a difference), but not massively lighter.
as for the power drop, it was mentioned in an article about the nissan v8 being used. power output is expected to be between 10 and 20% lower than it currently is, which is lower than what it was 5 or 10 years ago
You'd be mad to assume that COTF is to be slower than current cars.
Better suspension, transaxles, broader engines, specifically designed chassis instead of a monocoque.
It may take some time for engineers and drivers to grasp the chassis but they will be far from slower.
Because the commodores that were snapping timing chains do so much better in the Bathurst 12 hour...
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
