I just bought a netgear wifi extender that acts like a repeater. main reason i got it was so that i could plug my tv, ps3 etc over Ethernet (into the extender) and get better connections on them. working a treat so far
Previously had the d-link powerline AV kit (Ethernet over power) hooked up to a 5 port router which worked fine for ages then all of a sudden had a mass of connection problems between the two EoP units.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6119352
if you're talking point to point, a couple of guys from work have set up Ubiquiti Nanostations between their homes from the TV aerial, with ~500m distance LOS of course.
I can get signal from our Cisco WAPs at work up to 100m away (as in a usable signal)
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6120315
I could borrow a 'friends' internet from across the apartment block, must have gone through at least 2-3 slabs of concrete and was on the opposite side as i had to build a "dish" to increase the signal :D
So roughly at least 150m with the little enhancement, worked well. Got a increase of around 25% (up from 25%) so it was usable for its purpose.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6120413
ubiquiti? yeah, we're looking at creating a private wireless network to all the guys who actually live in Mildura for teamed internets, and therefore awesome torrenting potential
Yep, one of the point-to-point setups, it was ~$700 I think.
Pretty sure I have used those, seemed to be all good then a car pulled in and the link died. Was about 30M with two glass doors between the two points, I suspect one had metalic tint though. Ended up running a cable.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6122419
The ubiquti stuff is supposed to be really good from what i have heard.
Longest range i have seen is about 150m. We run all cisco stuff at our school, and had this older couple come in one day asking about there laptop, it was obvious they weren't students or parents either. They lived in a house that was about 150m away from the school, and since we moved fron netgear to cisco their laptop started auto-connecting to our schools open wireless network! They were running wireless B in their house from memory, and our wireless N that was more than 150m away was giving a stronger signal and they had somehow set it up so it autoconnects to our network! We had a laugh and had to set the laptop up for them and haven't had another problem since.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6126103
  • 4 weeks later...
just installed a setup on a farm
wrt54gl with dd-wrt on 150mw
used a 10dbi omni antenna mounted on a mast 15 metres AGL.
picked up a solid link up on a hill 11km away using a flat panel directional antenna. Did not do thoroughput test though :(
Was able to make a quality skype video call.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6163526
  • 1 month later...
I work for an ISP. We use the Ubiquity stuff daily. The M5 nanostations and bridges are great. Require a clear view to each other however. The Rocket M5's and M2's are also good. Havnt had much luck with the Loco 900s though. Tend to just call them junk lol.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6224654
