I just bought a netgear wifi extender that acts like a repeater. main reason i got it was so that i could plug my tv, ps3 etc over Ethernet (into the extender) and get better connections on them. working a treat so far
Previously had the d-link powerline AV kit (Ethernet over power) hooked up to a 5 port router which worked fine for ages then all of a sudden had a mass of connection problems between the two EoP units.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6119352
if you're talking point to point, a couple of guys from work have set up Ubiquiti Nanostations between their homes from the TV aerial, with ~500m distance LOS of course.
I can get signal from our Cisco WAPs at work up to 100m away (as in a usable signal)
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6120315
I could borrow a 'friends' internet from across the apartment block, must have gone through at least 2-3 slabs of concrete and was on the opposite side as i had to build a "dish" to increase the signal :D
So roughly at least 150m with the little enhancement, worked well. Got a increase of around 25% (up from 25%) so it was usable for its purpose.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6120413
ubiquiti? yeah, we're looking at creating a private wireless network to all the guys who actually live in Mildura for teamed internets, and therefore awesome torrenting potential
Yep, one of the point-to-point setups, it was ~$700 I think.
Pretty sure I have used those, seemed to be all good then a car pulled in and the link died. Was about 30M with two glass doors between the two points, I suspect one had metalic tint though. Ended up running a cable.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6122419
The ubiquti stuff is supposed to be really good from what i have heard.
Longest range i have seen is about 150m. We run all cisco stuff at our school, and had this older couple come in one day asking about there laptop, it was obvious they weren't students or parents either. They lived in a house that was about 150m away from the school, and since we moved fron netgear to cisco their laptop started auto-connecting to our schools open wireless network! They were running wireless B in their house from memory, and our wireless N that was more than 150m away was giving a stronger signal and they had somehow set it up so it autoconnects to our network! We had a laugh and had to set the laptop up for them and haven't had another problem since.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6126103
  • 4 weeks later...
just installed a setup on a farm
wrt54gl with dd-wrt on 150mw
used a 10dbi omni antenna mounted on a mast 15 metres AGL.
picked up a solid link up on a hill 11km away using a flat panel directional antenna. Did not do thoroughput test though :(
Was able to make a quality skype video call.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6163526
  • 1 month later...
I work for an ISP. We use the Ubiquity stuff daily. The M5 nanostations and bridges are great. Require a clear view to each other however. The Rocket M5's and M2's are also good. Havnt had much luck with the Loco 900s though. Tend to just call them junk lol.
https://www.sau.com.au/forums/topic/383311-wifi-range/#findComment-6224654
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
