Just finished making and doing this to my GTT. Very time consuming process but well worth the hard work and end results. I've made molds off a GTR, so can make more peices if anyone wants/interested in them. (I am in NZ though) Can make the gtr front, sideskirts, rear bumper, nismo skirts/caps, wide rear arches (not identical to gtr slightly wider). I used genuine front gaurds, and sourced bonnet and spoiler. As i say alott of work but the end result has been worth it, very happy. Couple pics for those interested.
Edited by mawzy
  • Like 1
that looks really well done.... let me guess your a panel beater or spray painter??? its just a guess..
No I'm a builder by trade, skylines just my hobbie/interest. Had 32, and 33, always done as much work etc myself, otherwise wouldn't be able to afford. But was lucky enough to get access to a spray booth for the paint. Everything else has been done in my garage
Stupid fake GTRs
Stupid arrogant GTR owner.
  • Like 1
http://www.rhdjapan....B25DET&x=20&y=8
You can obtain most of the costs from this web page.
I favour the East Bear Masterpiece Collection kit. It's what's on my car.
Budget:
Purchase: $4000
Transport: $1800
Fitting & painting: $300
A much cheaper fibreglass kit, can be had from here, with the wide body option:
http://www.ebay.com.au/itm/Nissan-Skyline-R34-GTT-2Door-GTT-GTR-style-wide-bodykit-/260821721289
This is not the VSpec II Nur look alike though. The masterpiece collect is, and also is FRP or CF.
Edited by TR33GT-001
http://www.skylinesa...06062011346jpg/
A cheaper fibreglass wide body conversion, can be had here:
However, this kit is not FRP, nor is it the VSpec II Nur look alike.
  • 2 years later...
For all the parts i make, can do at $1800NZ plus shipping (unknown) You would need to source bonnet and front fenders. If you aren't fitting and painting yourself, I would allow more than $300,
any chance your still making these parts?
  • 3 weeks later...
R34GTT to R34GTR. Not being an arrogant GTR owner - I just don't understand
(I have a 34GTT also)
Seems an expensive way to go.... If your that keen on the looks I suppose I can understand a little
but please NEVER put a GTR badge on anything other than a GTR
32 GTS-t's look a lot nicer with the GTR fronts on but IMHO not the 34GTT's
The black 34 above looks really well kept too
Edit: For the dollars mentioned above I'd upgrade to a 3076 with an .82 rear housing some ID injectors etc....
Edited by Sinista32
i think we can all agree that the GTR kit looks way better then any GT/T kit
i only did it because i did some front end damage and needed a new front bar and fenders and a bonnet was only a little more so i thought why not.
heres a before and after pic
and how it sits now (obviously will never put any GTR badges on it)
thats only the front end though, im going to get the skirt add ons and rear pods as well as pump my rear guards to fit bigger rims.
*sorry for the bad quality pics but i only have an iphone for a camera
Edited by IMPORTS ONLY
Okay persuaded - definitely a lot better
rims alone make/brake a 34's looks as well
also keep it clean of stickers
with the rear wing gone maybe think about removing the rear wiper and putting in a delete plug
yup definitely agree on the rims, dont know what i was doing with the stickers haha 34's look way better clean
and yup ive thought about getting rid of the rear wiper as a delete plug is only $50 but then the rear wiper jet is still there and that would look odd?
Sorry, I disagree lol.
Here's my proof, car using stock front bar with oem lip, nismo skirts and stock rear bar.
1781188_10152596897129409_1215710287_o.j
1973609_10152596897204409_1615966804_o.j
Edited by Charles89
Hey Charles, is that a GTR front diffuser?
Does that just bolt right on to the oem lip, or did it need a bit of modification?
I have the same front as yours, but that lip sets it off
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
