I'm thinking of putting a surge tank on my 260rs with a single 044, just looking for ideas of surge tanks and where to mount it,
If anyone has pics or other reccommendations please post your ideas,
I looked at fitting a walbro but is way too small for the in tank cradle, have thought about a nismo replacement but they are a lil expensive, the cheapest i have found one is $499 delivered from n power on ebay
Considering the Nismo is good for 450-500kw its worth every cent. If you want a cheaper pump get the deatchworks or aeromotive pumps, they are a highflow pump in a walbro package and can be easily fitted into any tank with a few hoseclamps.
The M35 comes with a built in surge assembly. Surely there is somewhere you can fit one under yours? If you decide to get one made, use the stock pump intank and run 044's off the surge.
My surge tank (3L) is in the car but it is very noisy although I have insulated the cover (was really noisy before). I have a walbro cable tied into the stock cradle and a Bosch 044 out of the surge tank. I would try to put the tank under the rear seat (under the car) if possible.
044 is $200 bucks, Surge tank, 150-200, new braided teflon lines + fittings (so your car doesnt stink like fuel everyday) - $200
Go the Nismo
Go the Nismo
(NZ$) my surge tank was $150 Walbro $200 Bosch 044 $300 Cover for surge tank $300 Insulation and carpet $100 there'e a grand without fuel lines and hours of labour. Unless you're into serious track work (don't laugh, I can't afford another track car) a really grunty in-tank pump is the way to go.
044 would fit perfect in the cradle in my tank but i've heard they dont pick up too well on the last 1/4 tank,
I also want to run e85 on occasions so i want a pump thats compatable, is the nismo pump ok with e85?
on what volt rating does the nismo flow that much ???? also with the walbro or deutch you need a direct power feed of around 13volts or more to make them flow there recomended settings . 040 can have picck up probs under 1/4 tank so just dont run that low surge tanks are the way to go if you want to make any sort of decent power its just a good sound investment ! i run a intank walbro wich feeds my surge tank and an 044 pulling from tank all mounted underneath my car near fuel tank and as far as e85 goes looks like a lot of the guys run twin 044 s
bosch 040 235l/hr @ 5 bar 12.5 volts 260rwkw (safe)
bosch 044 330l/h @5bar 12.5 volts 330rwkw (safe)
and from memory walbro on 13.6 volts 270- 280 on normal pump feed volts around 230rwkw
I didn't see the point in changing my set up.
I left the lift pump (in tank) as the stock GTR pump. These can be picked up for cheap to
2 litre custom surge tank that cost me less than $100 to get made
Single 044 that I picked up for 190
Various fittings and lines totaled just over $150.
Basically I never wanted any surge to happen on say a hard launch or on a track etc etc. Its good peace of mind for me as it removes one weak link out of my cars chain. I'd go the external set up any day
I ran the Tomei on ethanol for over year with no problems, same as Nismo apparently. They should be good for over 400wkw with e85 and will work on stock voltages if you want.
Im currently running twin Walbro's and have been guarenteed they will be fine with e85, from the testing various workshops have done.
I found this thread on fitting a 044 in a r32 GTR, the cradle in my tank is exactly the same, this would be a cheaper way of installing a 044, would there be any issues with mounting it this way?
none at all worked for me for 3 years, I only went ext surge so I could run twin 044 pumps if you only need 1 pump this is the best option. Fittings for 044 cost $25-30 they were on ebay when I did mine.
I think one 044 will be sufficent as i dont want anymore than 330kw at the moment, the 260rs is still a fsmily car & the mrs drives it most of the time,
Is it nessesary to have 2 to run on e85?
You need to deside what you want to do 1st because you will need to change a few things and retune to run e85 remember the mods to the fuel pump cradle are ireversible.
Have been prowling the web on different fuel set ups and found a lot of write ups on the honda forums in the usa about guys setting up 044 directly on line without surge tanks.
Standard or walbro in tank to standard fuel lines then 044 in the engine bay between fuel filter and rail,
They all seem to make very decent power and stories of any type of failures or problems due to being set up like that.
Has anyone else got a set up like this or can anyone comment on pro's or con's of doing it like this?
http://www.honda-tech.com/showthread.php?t=2389237&highlight=Fuel+Pump
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
