Hi all,
Long story short I have a coolant leak from my OEM cooling setup.
Turned out to be one of the end tanks leaking - where from I dont know at this time - could be end tank cracked (worst case) or could be just that the seal is gone. Will know more later.
My question is:
What is an advisable replacement item for my OEM setup which will achieve the following
  • Provide a higher level of cooling than the OEM setup
  • Look as OEM as possible (I dont mind going to a full Aluminium setup- just keeping it looking OEM is preferable)
  • Price can't be outrageous
  • Be able to cope with 35 deg / 40 deg days in SA in traffic ( I understand that this has more to do with the fan setup than anything else)
  • Fit must suit OEM cooling setup i.e. OEM clutch fan etc.
Cheers,
David
https://www.sau.com.au/forums/topic/383436-what-radiator-to-get-to-replace-oem/
Not having massive cooling issues atm in normal weather upto about 27 odd degrees. After that the "Hot Fan" at the front of the car switches on.
All of this being said, I dont want to replace the std radiator with something that will only EQUAL the cooling capacity of the stock setup.
Considering the car is making probably twice the amount of power than the original motor made in that car; the cooling is probably a little underdone if anything.
1 such person here. A koyo radiator nor resides where my cooling pro used to be (lasted just over a year I think)
Yeh I was looking at getting a Koyo, but they are decently expensive compared to some of the other options on the market.
However, a wise man once said, you get what you pay for - and here is no different IMO. Heard a few bad stories about the 52mm thick after market items and them being no better than the OEM setup.
I have had a triple core China spec alloy radiator in my car for something like 5 years now. Much more cooling ability than the std radiator. So much so that I had to replace the thermostat imediately after I did the radiator, because the old thermostat must have been stuck open, which was working alright on the original rad, but made the engine run totally cold and use 100% more petrol on the new radiator. Fits well, never given me a moment's grief. Would not put an original plastic tanked radiator into the car in the face of that.
$220 delivered for mine, I think its a little thicker than what the stock one was but otherwise exactly the same as stock
Thermo fans are shit!
can't believe you said that
I could...
Anyway stick with the stock clutch fan/shroud set-up.
And do NOT buy a $300 radiator of ebay. If you want it to do the job properly you'll be spending upwards of $500 for a double/triple pass item. Most will still retain factory mount/shroud & fan without a problem.
Agreed I do not want a ebay POS
However, any recommendations on specific brands?
PWR make an awesome 3 pass I hear, however the price is a little out of what I want to spend and overkill to boot.
Ye the PWR one is north of 800 IIRC.
Race Radiators in Melb make one, I've got one in my GTS-R. Works very well.
Eeeeerrrrrr .....no....
In traffic, at the lights, yes you will. They spin and push more air than the clutch fan at idle. Some cars will rise in temp at the lights. If you had the fan spinning faster it will cool the car, at idle, in traffic. My op was about this situation, not driving.
get an electric water pump, you will gain power by freeing up the engine from spinning one more pully.
Oh and in my GTR - on a 26 degree day, 5 laps flat chat of the Thunderdome (so around 5:30 @ full noise), hottest I saw was 95 degrees using a triple pass core.
Oil temp was certainly getting up there however, but that is unavoidable.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
