  • 4 months later...
Hey guys. In last time it was a bit quiet about the car.
After rebuild the car I got a new problem, a cracked cylinder head. The result of this was that
Now this problem is fixed and the guys from H.I.P. will build the car together. I hope I can drive the car in two weeks to the Fast-Car-Festival in MotorsportArena Oschersleben.
I also bought some other parts in the last time:
- Mines cam shaft cover baffle plates and the BNR34 key
547606_580543305289833_584170295_n_zps8d
-TOMEI turbo outlet pipes
198881_594020137275483_170010463_n_zps67
- and the Nismo brake lines
936224_594379803906183_2050013481_n_zps1
I used the time to work my getrag gear box over. Here the picture where I picked it up from GETRAG - Heilbron, Germany
401955_588136804530483_2127717137_n_zps5
That are all of my news.
I hope in next time I have new pics like that ;)
778767_549421535068677_130408581_o_zps1c
  • 1 month later...
So, the car is back on road again =)
I have the BNR34 back since last weekend.
I run some laps on the airport at Skymeet 2013 in Bautzen and the car felt very good.
On froday I picked up my baby from High Import Performance
1005092_616345085042988_597219206_n_zps6
Saturday: Skymeet @Airport Bautzen
(Photos by www.Pixelrev.de)
2013_PixelRev_Skymeet_IMG_3957_zps243f01
2013_PixelRev_Panorama_0001_zpsd28a5f69.
And here a little shooting with the car, still @home in Leipzig =)
At last, a really great pic from AT-Fotogrofie
1043941_547724418625663_1221926628_n_zps
  • 1 month later...
2. After Reisbrennen I had two photo shootings
Chrischi from Caught and Photographed
1150525_583895321656143_130965947_o_zpsb
1149764_584181394960869_24137074_o_zpsfb
1185201_584328181612857_1923593724_n_zps
999757_584328211612854_1287504262_n_zpsa
1094499_584328278279514_1763801652_o_zps
1146199_584328131612862_170692975_o_zps6
998780_584328244946184_276895794_n_zps4c
960003_585001974878811_134312447_n_zpsf3
and here with Christian from CK Phtgrphy
1119797_645200588832736_885794433_o_zps0
1150761_645201162166012_1829501573_o_zps
1149597_645221552163973_481204973_o_zpse
Here a little special, a friend made a model in 1/18 scale of mine =)
1146136_667796613245451_1643480855_o_zps
1096984_705809589433858_970976041_o_zps3
Here a new video from track (MotorsportArena Oschersleben)
  • 3 weeks later...
Hey guys =)
After a few weeks without forum I have some news and a lot wonderful pictures.
1.
Next photo shooting with Philipp from Phigraphie.com & USED4.com
And I have to say, the pics are so great! Look here
1233109_513471012068246_820094281_o_zpse
919326_517937321621615_1959367240_o_zpsd
1015424_517938288288185_1751691383_o_zps
1090922_517937584954922_863520772_o_zps8
1233126_517938451621502_2138463663_o_zps
1264231_517937728288241_435938480_o_zps5
1243341_517937558288258_1947329792_o_zps
1239090_517937481621599_727064747_o_zpsb
1264278_517937954954885_1525380434_o_zps
1264278_517938111621536_683228906_o_zps4
1268780_517937794954901_1999968446_o_zps
1265899_517937938288220_1209769432_o_zps
1269527_517937308288283_1435212594_o_zps
856544_517937924954888_391139132_o_zps39
1266645_517937371621610_1257080678_o_zps
1272830_517937694954911_708003433_o_zps6
1276641_517937341621613_1541568720_o_zps
1275299_517937461621601_609812690_o_zps4
1276744_517937854954895_1211303366_o_zps
1276341_517938511621496_1770433675_o_zps
1277542_517938308288183_840315994_o_zps8
1277394_517937491621598_1566782098_o_zps
1277707_517937554954925_1112088471_o_zps
1294509_517938504954830_1263241081_o_zps
1292242_517938064954874_233104811_o_zps9
1276657_517938121621535_711633104_o_zps1
2.
Next service time by H.I.P. (High Import Performance)
- new wide band lambda sensor
- new 3.5bar map sensor
- new IAT sensor
- and the most important service new mapping by Uwe from H.I.P. =)
Now the car feels so great and powerful!! So happy with new setup.
3.
My own shooted pics, hope you like it =)
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
