I have a problem with my BNR34 UK-Model with Link Ecu
I have no 4wd and A-LSD and the fail code 72 (TPS)
After I bought a new TPS I wanted to calibrate it and now the problem.
I can only calibrate it like in the BCNR33 manual (0,4 and 3,8 Volts on Pin38) but the BNR34 manual says I should calibrate to 0,5 and 4,2 Volts. But this isn`t possible at max I get 3,9 Volts or so and this dont fit at idle....
next problem, my mfd showes around 50% at full throttle. So I checked pin 56 and there I have 0,25 Volts at idle and 2,1 Volts at full throttle. but this should have 0,5 and 4,2 Volts or not?!
What is going wrong there?! =(
__________________
Good build thread man. 1 thing I didn't quite understand is why didn't you go for a reasonably sized single turbo setup instead? I had my last R34 GTR with -5's and now the R32 with -5's, both are laggy as f**k. And went in my friends R32 gtr with a single T04Z setup and 2.8L engine, the thing has lot more response! You did a full hearted engine rebuild so wouldn't it be better if you ditched the twin for a decent sized single turbo setup? That way you would have got more top end power with better response and less turbo lag. Just my personal opinion... :)
Edited by G0Z1LLAAAAA34
  • 1 month later...
After problems with my Link ECU and the AWD System I got my revised ECU back. Its all fine now =)
Throttle: ECUPin 38 and 56 = 0.5Volt
Vollgas: Pin 38 und 56 = 4.1Volt
No 4WD & A-LSD light, all fine =)
I bought some speedo LEDs , but I need better ones =(
But red light is looking really better I would say =)
Big boys can also have small toys^^
1st my AutoArt 1:18 BNR34 R-Tune in red
2nd my HPI 1:43 BNR34 Z-Tune in limited red/black edition
So, finally I hope you had merry christmas and wish you a happy new year 2013
Happy new year guys!
Here are my first news for 2013
This is engine bay before
and here the engine bay now, with my GReddy Suction Kit, but without my apexi filters because I need other adaptors
And also my toy collection is complete now =)
My Sky is getting famous^^
The story: We have done a photo shootig in year 2010 with a model. Now, two years later this model campaigns in the television show "The Bachelor"
This is the reason why she is in the bestselling newspaper called "BILD" now, with my car.
Here are the pics
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
