race control will be use to seeing gis running into everyone.
anyways, the best news i've heard for tomorrow is it might rain. :banana:
more on cotf.
http://www.v8supercars.com.au/technical/carofthefuture/thenewgenerationofv8supercars/tabid/1418/default.aspx
Edited by tweety bird
Yeah the transaxle is by Albins Off Road.
I know of a certain Aussie Superlap/time attack car eagerly awaiting the chance to swap the current Hollinger S6 for a new Albins Transaxle. ;)
There'll be a plethora of Hollingers available once to COTF launches..... one would assume. Shame the V8SC version isn't really suitable for most of us.
Does this car happen to be black?
Everyone I know who has actually driven the circuit says it's the most exciting street circuit to drive. It rewards the brave, and punishes the impatient, everything you want from
Besides the fact it takes away from all the other nsw
venues the circuit deserves a place in the championship.
It was entertaining racing despite the high repair bills many teams now face.
Don't totally agree with rewarding the patient as it seems the impatient get the rewards
Personally it would make a better time attack track than a race track
I thought our governments plan was to get speed off the streets, so I spose this means cutting EC in half , so you get half the value for the money - really don't see this as an inticer.
Wouldn't our taxpayers money be better off supporting Bathurst Extension (not only cause I am close), assistance to Wakefield Park or other venues sought as a permanant structure.
Cheers
Govt. doesn't actually care about speed off the street Stu.. only votes.
Unfortuately motorsport (whilst a huge sport across the community wide, as a spectator sport) doesn't suck in massive political advantage.
I only wish we could get the amount of land that GOLF courses have.
Think about the average 50yr old impotent kock running about on sunday morning, smacking a rubber golf ball... vs 180km/hr at T1 at EC.
Sad, really.
I have SIX major suburb-sized golf courses within five minutes ftive of my place. Give me the shits.
Sad, really.
Time to buy a set of clubs, and a buggie and turn the courses into your own track...
Golf courses dont make any noise, are popular with the retired and increase land value.
Most race tracks can be heard from 5km away which affect a few thousand people.
not to mention polution, etc.
and yeah the noise is a big thing. on a quiet night, with the wind blowing in the right direction, when i lived out of town i could hear the speedway, and it was on the opposite side of town, about 15kms away as the crow flies.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
