Got an adaptronic plugin ecu for my RB25, still using standard plenum and cooler to TB piping.
Where can I connect the IAT sensor? As im not running a BOV(BOV is still bolted on but is blocked) i was thinging of making a blanking plate for where the BOV sits and screwing the sensor in there.
Any one see any probles with that? Will it be too far away from the TB? Heat soak issues?
Imrunning microtech and my air temp sensor I drill a hole a tad smaller than needed and tapped it to the correct thread I did this on crossover pipe about 10cm away from tb
he has done it in a few threads now...said exact same thing in all of them....seems a bit fishy lol
like a dodgy flamin mongrel trying to get his post count up out to pm people
So the thread pitch you tapped is wrong only real way to fix it now is either helicoil or get a adaptor to make the size of sensor larger and make the hole bigger and retap
