Hi all, I have just installed a high flowed standard turbo and hybrid super monster i/c to my '94 car, standard computer (had the opportunity to get the turbo now so thought I may aswell put it on, plan to get pfc soon). When i test drive the car at my normal 0.85 bar (avc-r) it pulled well to 4-5 grand then dropped a bit before pulling real hard from 6ish grand to redline. Turning the boost down to 0.75 bar helped, and at 0.7 bar it's barely noticeable, suffice to say this never happened with the standard turbo. I already have a bigger fuel pump and adjustable regulator.
Is this the infamous r33 standard computer power dip? Is so, sh*t it's severe!
Thanks in advance....
https://www.sau.com.au/forums/topic/38355-r33-computer-power-dip/
yup.. stock ECU isn't designed for turbo upgrades.. thats what happens generally.
Didn't whoever installed the turbo tell you this before they put it on?
I purchased the turbo second hand from another customer where I get work done on my car sometimes, apparently this guy ran it on his car with standard ecu for a while before getting pfc aswell, so it thought bugger it, i have the turbo, may aswell put it on. I put it on myself in the garage while i was installing my fmic. I had heard of the standard ecu power dip but never experienced it, so yes i didn't expect the ecu to handle it too well. In a way that's good though, at least I know the turbo is flowing more air at the same boost pressure than the old one.
I was just a bit worried that something wasn't right (esp because I put it on myself), but all seems well, just need the pfc.
just a quick question guys, I plan on going down this same path soon, and hadn't been aware of the computer prob.. what is the "pfc" is it a new chip?
I actually installed a boost controller a week ago, and aside from that it's stock, but i've noticed in the last couple of days, that my car is doing something similar, but dying at about 3-4k then kicking in again... turbo and ic are stock, could this be computer related too? My boost levels haven't changed though... It sounds and feels like something is either slipping or losing power/air then jumping back up.... This only happens after 1st gear. I'm mighty confused... any ideas???
Hi guys
Im experiencing the same as madmoomoo at about 3-4k, since a week after my boost controller was installed.Only does it on 12psi everything is stock apart from filter.Never does it in 1st gear.
Please shed some light its really annoying having V8s catching me when i change into 2nd!!!
I have experienced a similar problem with a minor power glitch between 3k - 4k after installing a turbosmart E-boost. It doesn't matter what boost setting I am running (ie. setting 1 is standard boost) the glitch is always there but maybe not as severe as you guys seem to be experiencing. I don't really notice it when on full power (traffic light drags) but noticable when driving normally
If I turn the E-boost off the glitch is gone
I have standard Turbo, FMIC & Mines computer
The next upgrade I am planning is a Power FC and hoping that with proper tuning I can eliminate this glitch
any piggyback fuel management hardware can fix this problem... (ie. s-afc or e-manage) but thats more of a bandaid solution. best option would be to go for a whole replacement ecu like a powerfc or wolf3d if you can afford it.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
