I recently had a set of Blitz 525CC Injectors professionally installed in my RB25DET NEO. Granted the shop wasn't a tuning shop which I didn't think was a big deal since I could make the injector corrections on my Power FC to start the vehicle. (Or so I thought) Looking for someone who has this setup to see if there were any issues with others intially not starting. (Car was in good working order prior to install) I changed the injector setting to 70.8% / .35ms as well as had a tuner verfiy but it still not working. Between the installer and the tuner both aggree everything is in order but fuel doesn't spray from the injector. However it goes in and returns from the rail. I was told it might be possible the latency of the injector is past the spec of the driver of the PFC. But I want a second opinion since I dont think this is the case.
The fuel pump works and was installed brand new less than 3 months ago.
The Injectors are new and recently flow tested. (31209)
Fuel system is good. (lines not crossed & has pressure)
The PFC was working prior to installation and has been professionally install and tuned with the standard Injectors.
Spark plus are getting spark.
TPS,CAS and other sensor are functioning correctly.
Any thoughts?
From searching seems alot of people sold them only one person mentioned anything about a PFC.
Did you check if the injectors are getting a pulse? That will tell you if there is a signal being sent to the injectors to open up. Injectors are always shut until something tells them to open up and for how long.
Yes, I did and they are. I just dont think they are long enough to spray fuel.
