Hey Guys,
I'm looking at getting all of my intake piping either made up or buying a kit depending on recommendations and others experiences. Currently my intercooler piping goes through the stock holes near the POD filter. I wanted to change this so I can make a custom intake box. I'd also like to get a hard piped CAI but not sure where to get one from or if anyone knows where I should go to get one made up. If anyone has any idea's or tips regarding this I'd appreciate it. I've checked Ebay but I'm not really interested in cheap "clip together" pipes that are for sale.
Located in Southern Adelaide.
Piping is for S2 RS4
Cheers,
James.
https://www.sau.com.au/forums/topic/383593-intake-piping/
Also, AM Performance were going to do one for me. Give Andrew a call, 0401865373.
His workshop is at Greenwith, so not South, but worth travelling for.
Cheers for the tip Ryan, I'll be sure to get a quote from him.
Obviously I'd like to travel as close as possible due to work every day.. But if it's worth the trip I'm sure I can organize something.
Does he also do Silicone hosing and fixtures, etc.. I'm looking at Updating my Engine Bay if possible, but haven't been able to find decent workshops anywhere.. It's always a case of either trying to rip me off or just do dodgy work...
Cheers for the help!
https://www.sau.com.au/forums/topic/383593-intake-piping/#findComment-6119465
I can vouch for Andrew's work, top notch stuff.
He mainly does performance mods and fabrication, primarily exhausts and dump pipes, so I'm sure the fixtures are fine. Not sure about the silicone hosing but won't hurt to ask!
Tell him Ryan with the M35 sent you.
https://www.sau.com.au/forums/topic/383593-intake-piping/#findComment-6119516
Hey Guys,
Cheers,
James.
honestly mate, for all the stuff your looking at doing you'd be better off just converting it all back to stock. the factory airbox is not a restriction and it comes with its own CAI. plus it wont cost anything if u still have the bits. :thumbsup: ive got no idea where the rumor that pods give u more power came from but it just isnt true. try them out back to back (stock VS pod) next time ur on the dyno.
https://www.sau.com.au/forums/topic/383593-intake-piping/#findComment-6119832
Yeah man I understand from a power point of view, but I'm not looking at doing the piping for any power gains, I'm doing it to tidy up my engine bay. The stock stuff is fine but if I wanted a car to keep stock then I would have bought something else.
Cheers for the advice though.:thumbsup:
https://www.sau.com.au/forums/topic/383593-intake-piping/#findComment-6119998
Meant to ask Ryan, You still parking at Topham?
https://www.sau.com.au/forums/topic/383593-intake-piping/#findComment-6120000
Lol was there today. That's usually where I park if I drive in, but I only drive in once every 2-3 months, when I have heaps of stuff to carry in. Too expensive to drive in and park every day.
https://www.sau.com.au/forums/topic/383593-intake-piping/#findComment-6120388
Yeah man my wallet is usually pretty light after parking there but unfortunately for me, I'm a creature of convenience. And starting work at 4:50am means no buses.. :glare:
https://www.sau.com.au/forums/topic/383593-intake-piping/#findComment-6120532
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
