Ok thanks guys!
And as far as good and bad catch cans, there just cans! as long as they dont leak how is one better then another?
There's a difference between a simple 'catch can' and a proper oil/air separator.
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6119409
Ok thanks guys!
Size need to be at least 2Litres (or to suit regs if you're racing)
and some kind of baffle system to encourage oil and water to precipitate into the can and just let the gas go out (to atmosphere for track car or inlet for street car).
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6120541
There is probably a viable off-the-shelf item, but I want mine to sit in a specific spot so custom is the way to go for me.
That said, I'm yet to actually find a decent looking off the shelf one... Anyone had much luck with that? I know RIPZ makes them, but I believe only on request?
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6121846
im not to sure im trying to work it all out myself now but as i mentioned before would steel wool do the trick
the only way i can think it would work is say you have the inlet and outlet next to each other and have a partition/baffle in between made from fine steel wool so its like divided into 2 tanks inside by the steel wool so air and oil go in one side and just air comes out the other because the steel wool has caught the oil on the way through
Edited by luvpsi
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6122200
If you had a square tank you could easily make baffles out of square pieces of metal which left a gap and alternate the gap left and right so that the stuff that comes in has maximum contact with the plates and the liquids drip down to the bottom of the tank .
https://www.sau.com.au/forums/topic/383612-oil-catch-can/#findComment-6122243
