The genuine tail light surround is a grey colour, it's much darker than your paint work and would look awesome IMO but it's personal taste. Are you looking at a set of JDM tail lights? Would look awesome. I've just rebuilt mine.
Yer im going to go JDM lights down the track, the tail light surround can always change colours later if i want. The lights look really good, starting to do some work on your 110?
The car has just been sitting for the last month around chirstmas-new years my work really gets flat out, hope to get back into it in the new year.
Cheers Brad
Yeah they came up good as new. Yeah slowly starting work on it. Pulling things off and doing them one at a time.
I'm trying to decide what to do with plastic that needs to be re-chromed. The GTR tail light rings I have need to be re-done and I'm not sure if it's just easier to buy a rep set or what.
  • 1 month later...
Hmmm sydney weather is crap plus only have a single garage so work has been slow.
I got some new parts to fit up tho if we get a dry weekend!!!
Thanks to john for the window winders
And some parts already started to fit to motor in the one fine day we had this week.
Couple of things learnt today, first and most important is always ask before buying lol. And here are the rest.
240k and 240z do not have the same door handles.
Ebay photos looked close
But different shape and size
C110 and C210 do not have the same door locks.
Look the same from the front
But from behind the they are different, i tried changing the backs over but they are different too.
Installing this required more skin then i liked lol
Also 240z pedal boxs are not the same as as 240k, but the 260c looked about right but was not able to strip this car of it.
Nice fuel filler cap, is that a new one?What are you planning on doing for door skins and seat trim etc? I'm investigating re-trimming at the moment
Nar fuel filler is old one, i have a new breather tho.
My trim is mint, but if your doing a GTR style i may be keen, on a set too, what are you going to do with
the seats tho?
    • Not alot of room in the front or mid pipe to play with Helmholtz chambers, plus they are pretty hit and miss getting the length and volume right, and time is money when it comes to trial and error testing at a exhaust shop, it isn't like test fitting mufflers or resonators From previous experience with exhausts and trying to tone down the volume and eliminate some drone, a resonator in the mid pipe typically make it much better,  and even possibly stop Jackie complaining about it, me, I really don't notice it that much, but, I am pretty deaf 馃ぃ
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30掳bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • www.rollracing.com.au tickets aren鈥檛 live yet
