If it was sydney i would take off your hands, i just finished my L24 today should make it the slowest car on SAU lol.
Im still waiting to get my parts from Japan(not posted yet), once they arrive i hope things will pick up again.
  • 3 weeks later...
For those that want to see pics
Hmmm so i got some nice pics today before the rain,
Also a good day to fit the windows(could not get a new rear window)
And fit the new badge
This has made me want to finish the car even more so updates should come a little quick for 2 weeks or so.
  • 5 months later...
Going back to Feb, how did you get on fitting the radiator. I see the bottom outlet is angled up, rather than straight out. Did the hose go on ok, and which model was the radiator designed for? Where'd you get it?
Sorry for spamming you with questions, if you hadn't already guessed, I'm also keen to upgrade radiators, but there isn't much off-the-shelf stuff for c210/240k.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
