Hey guys
recently i was cleaning up and found some NICE OLD SKOOL SPEAKERS ( TECHNICS SB-F40)
these bad boys were made in Japan in 1983 they are made for home and car use
i dont really have a need for them in fact i did not even know i had them.
I was thinking it could make a nice edition to some ones rear parcel shelf with that old skool look .
I have tested them and they work and sounds really nice, as you would expect from japan
they are in very nice condition only like 2 minor wear marks
Specs
The woofer uses a honeycomb disk for exceptionally smooth response. They have a cast aluminium front chassis and very solid plastic backs.
These are very cool, bookshelf type, extended high freqency studio monitors. They have a high frequency extension to an ear splitting 35kHz.
3-way bass reflex / sealed system
14cm low-range driver, 5.2cm mid-range driver, 2.8cm high frequency driver
Impedance 8Ω or 4Ω adjustable via front mounted switch.
Output sound pressure level 87dB
Frequency band 75Hz~35kHz (-10dB)
Crossover frequency 1.5kHz, 5kHz
Weight 3.5kg each.
I have put some pics these are off google i will get some of actual when i get home but there are in the same con and same colour
make me some offers if ur keen
i am happy to ship australia wide at buys cost
https://www.sau.com.au/forums/topic/383631-old-skool-rear-speakers-for-sale/
i forgot to mention that one part of the speaker rotates around so it and stand up for home or lay down for car i too some pics of this
the speakers have mounting holes in the bottom and top too
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
