Hi everyone,
sorry to hit you all with this, but im pretty new to the whole turbo thing and im finding it a bit hard to find what im after when searching as alot of posts have very mixed opinions.
Im looking to purchase a new turbo shortly for my 32. i have all the supporting mods for around 240-250 rwkw and am just finding it difficult to choose a turbo. so obviously i want something that will easily flow the 250 but still retain some sort of response becase it will be street driven.
Im tossing up between the gt2860rs and the 2871R (mind you, i have only looked at garrett s far). the other confusing thing for me is the different housings, i dont want to pick the wrong housing for my application.
im also after a turbo thats straight bolt up. i can alter the cooler piping if need be (i assume i will have to) but i just want standard exhaust and dump flanges
Any advice is greatly appreciated guys
Cheers,
Brad
Edited by NinjaWhale
https://www.sau.com.au/forums/topic/383647-rb20-turbo-choice/
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
