Fs: R32 Gtr Parts
  • Replies 50
Also selling my 888cc siemens injectors low impedance to suit gtr rb26 after $400 specs below
These injectors flow 86 lbs/hr at 43.5 PSI ( 3 BAR )
FEATURES:
  • Genuine, reliable Siemens Injectors
  • Excellent response characteristics
  • Robust Design
  • Low Impedance
Specifications:
  • Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (Peak/Hold driver circuit required)
  • Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 86.2 lb/hr = 888 cc/min = 652.2 g/min
  • Connector: Bosch EV1
  • Spray Pattern: Pencil
Uploaded with ImageShack.us
Edited by ATLRGE
Passenger side seat $150
Rb26 standard fuel rail $10
R26 mines pod adaptors running z32 afm's with blitz filters i think $150
R32 gtr dash board slight lifting. $150
R32 gtr lower steering column cover $30
R32 gtr Front passenger side gaurds $150
R32 gtr doors less switches and mirrors $120 each
R32 gtr boot interior lining rear over boot latch $30
R32 gtr boot lining pass side $30
R32 gtr front windscreen gutter tray no cracks $50
R32 gtr stock intercooled $100
R32 gtr centre console $80
R32 gtr gear surround plastic with 2 screw holes on pass side with no boot $50
R32 gloove box $60
R32 gtr driverside kick panel $20
R32 gtr plastic sill covers $30 each
R32 gtr interior light $20
Ame wheels to suit gtr with 215/45/17 tyres that are 80% tread $450
Paid for one of the window rubbers and got sent the wrong side, contacted ATLRGE back and he said to keep it and will send the other one the next day express. That was over a week ago, have been constantly trying to contact him but no replys. BUYERS BEWARE!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
