Wasnt sure where to put this... this section seems to be full of the smartest blokes and highest traffic. Ime about to embark on what i know will be the more time consuming painful job you can do to a car... wiring it from scratch.
who here has done it and can give me some tips.
Do i use any of the factory nissan loom/fuse box or do i just start from scratch?
https://www.sau.com.au/forums/topic/383674-full-car-rewiring/
Fag. Lol.
Hmm ok, wipers, yes i can understand. Electric windows adds weight uleh! But they never came with manual windows so your kinda stuck..
The wiring for power windows is a little complex as it usually routes all over the place to the necessary relays. Usually there's a thermal overload for them somewhere.
Have you ripped out things like all the cruise wiring, abs, radio wiring, speaker wiring, air con/climate control wiring etc.
from those that i have spoken to... dewiring an existing loom seems to be the best way to go
Dewiring is a pain in the arse! But it does have advantages.
I look at it like this:
If you are leaving everything in it's original location then yes, dewire.
If you want to retain factory switch gear then dewire.
If you want to relocate fuse boxes and have switches for everything then buy a kit.
If you want to relocate fuse boxes and retain factory switch gear you end up with something like the picture which has partial factory dash and switch wiring, modified engine loom to suit relocated fuse box, custom alternator, battery, starter, and lighting wiring. I also did custom power window wiring. It was a PITA.
if your de wiring try this site, might help you with a tidy engine bay loom. and it has a lot of options.
http://www.chasebays.com/product/nissan-240sx/chase-bays-products/chase-bays-engine-harness--nissan-rb25det
as for the wipers, if you have ditched everything and kept wipers then you need the s14 loom for the full 6 wires(but thats easy to chop) you will either need new connectors or keep the old connector next to the computer. i would ditch the whole setup and run a switch and relay for them.
have a look at that site again, it might give you the wipers option?
thanks for that man. the engine loom will be easy as i will be getting a haltech with a flying loom. so will be able to start from scratch with that one,
well i ripped everything out of mine.. so much wiring!!!! far out. Makes me think that de/wiring it will be more time wasted then good and i might just be better off running new wires and loom.
I wired my car from scratch, wasn't overly hard, power windows where abit of a prick but I just used a 3 way momentary switch with 6 terminals on the bottom. You need to switch the ground/positive to go up/down.
Remember when wiring the alternator that you need a check light. Pm if you got an questions.
All I can say in my limited experience. Is buy a pair of Deutch plug crimpers ( I think there are 3 different sizes so be careful). Now make a friend who is an autosparky for earth moving equipment and or truck trailers like I have. Get him to buy all the deutch plugs at about 1/5th the price that any normal person can buy them/ sells them. (a plug I was quoted $15 bucks for cost him about $3-4) make sure you get some good quality side cutters and good quality wire strippers, good quality heat shrink and a tube dielectric grease. (all the things your new mate can source for a fraction of the price you can) last step invite your mate around for a bbq on a Saturday and explain to him that your a little confused on how to use the crimpers correctly and that you need about 2 dozen examples b4 you will get it right.
Your car is now rewired lol
the 2 companys that my mate deals with are below.
http://www.connectsource.com.au/
http://www.genr8.net.au/
YOUR WELCOME
Chris
can you pm me more info trent?
also whats the racepak unit? im getting one of their IQ3 dashes also
Simon i have pm turned off, email me [email protected] and i will forward on the details.
I wired our 180 drift car from scratch. Its really easy if you know basic relay circuits. The ECU control is made up of a few relay circuits and thats it (were running PFC on the std ECU loom).
We thought about de-wiring but what a pain in the arse! There are sooo many things to get rid of, and if you cut one wrong thing youll be scratching your head for weeks because you wont understand the nissan loom. Youll spend as much time picking the tape off it as making a whole new loom.
I used the old 180 looms for the relays and relay plugs, and used the fuse box to hold the relays, hell, i even used the wire from it. All i bought was a 10 fuse holder from burson. The only paperwork I needed was the ECU pinout, and a ECU wiring diagram, for power, ECCS power circuit, tach and fuel pump run.
Well be running electric windows which are easily done as above, google a simple motor forward/reverse switch setup. If you can find a wiring diagram for the wipers thatll be a big help, otherwise just probe it before you remove it, and reuse that part of the loom.
Brakes/reverse/headlights are all simple relay circuits as well obviously. There are some pics in our build thread BUT its not finished yet so its not zip tied and conduited so it looks like a head ache but really its not.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
