I have an r33 gtst rb25det skyline i took it in to get dyno tuned after installing a new engine
the mechanic i took it to is trying to find a problem with why its so gutless but dosnt realy know what it could be. its got a kkr t4 turbo thats shit i need a new one but that dosnt explain why its only making 90 kw when my old engine was making 180kw its a series 1 but with a seris 2 engine iv got a nistune board brand new splitfire coils brand new fule pump full service new oil and all filters its got a new clutch new everything exept turbo why is it running like shit. the turbo is still good just if everyone thinks its that iv tried it with a stock turbo but have the same problem.
please help meeeeeee :(
https://www.sau.com.au/forums/topic/383691-my-skyline-is-gutless/
Compression test, fuel pressure test, timing, spark plugs, ignition lead and coil tests, a/r ratio's, test all connections and coolant temp sensor as well as o2 sensor, exhaust system check, blocked cat, waste gate actuator, boost leak?
cam timing too ?
Could be something simple mate, you know what i did once, when i was young and inexperienced, i dropped in a new motor, new intercooler and pipework.
Put it all back together, fired it up, would idle, but barely rev, could barely get it to move.
Turns out i had left a rag in the intercooler pipework (before the intercooler luckily) that i had put there to stop dust getting in there. Such a simple thing, took me about 3hrs to think of it!
Took rag out, engine was fine.
90kW i'm assuming the engine is having trouble even reving?
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
