Hey guys up for sale is my td06 has don't less then 30km only dyno time selling as a whole kit everything you need $1000 selling due to going to 25
Rb20 block still tight 120,000 on the motor $200
Rb20 head needs machining $100
Ask for any other parts message me 0449831518
Yeah mate everything you see in the photos. Turbo, wastegate, manifold and front pipe. Iv bought a new turbo so I no longer need this setup and don't want it sitting around going to waste
Ok I'm breaking it up
Turbo $700 Ono
Watsegate $200 Ono
Manifold $200 Ono
Front pipe $100 Ono
If your not happy with prices make me a offer will still sell as a kit for $950
Now also up for sale is a rb30 block needs a quick skim $150
A set of cp forged pistons for a rb30 one has dents on the bottom but still in perfect condition come with pins they need rings tho $600
x5 rb30 rods $80
Rb30 water pump $50
Rb30 oil pump $50
Edited by Bsa
td06 almost new $650 without lines
Rb20 block still tight 120,000 on the motor $100
Rb20 head needs machining $50
rb30 block needs a quick skim $50
A set of cp forged pistons for a rb30 one has dents on the bottom but still in perfect condition come with pins they need rings tho $500
x5 rb30 rods $50
Rb30 water pump $50
Rb30 oil pump $50
    • Neo IACVs have water plumbed into/out of them to provide the heat to close the AAC. I am also unsure about vanilla 25s, but maybe the extra plumbing on that is water.
    • Those injectors are 100% Nismo 555.
    • I found this in another thread, now I'm second guessing myself and thinking there was a vac line from near the throttle body to up to the IACV too.   https://saufiles.s3.ap-southeast-2.amazonaws.com/post-59171-1251456228_thumb.jpg
    • Hey Duncan,  What ports are on the plenum itself? The new part welded up for the AAC looks like it's a T Piece to go upto brake master, and the other side into the plenum to feed air in. Brake master vac line on R33 from memory has a one way valve inside of it I believe (middle of pipe). I'll check mine tonight when I get home, I think that pipe is still sitting on my R33. You're also testing my memory, but I don't believe the R33 has a cold start valve, it just has the IACV doesn't it? That second smaller port on the IACV itself from factory, goes down and under the inlet manifold, but I can't remember what it plumbs to.
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
