S A U N S W - Texi, Sos, 12Th February 2012
  • Replies 209
Posted Images
i seem to pull around 1-1.2G on the street with no worries.
and the last "kahna" type event i went in, was also ok.
ive got plugs to install for the speaker wiring, just not the power.... ....yet.
and still have to buy an extinguisher.
but looking forward to the day.
my first texi, im a little excited :woot:
Tats had metal brackets holding his in... A couple of spins dis lodged it... It then smashed the outter guards to pieces... Causing the car to be around 1 - 2 inches wider on each side...
You will be surprised the G-Forces that you pull when you spin a car...
ill im getting from this is cheap pumped guards....
joking, joking, will work on the wiring leading up to the event.
and besides, my straps rated to 2T im pretty sure, and mounted off the rear strut brace, it looks so hectic, all the wimenz drop their pants at the very sight of it :P
Hi all
I'm in as a first timer for TEXI but have let my membershgip lapse,. I will rejoin on the day.
Also, I have sold my V35 and will attend in my...er...um...er... XR8, hope that is okay?
Regards
Geoff
Entry fee paid. Ref : Texi Ryan Ambrose
re the ASAA license- I paid and supplied forms last time, should I have received something in the mail? I have no license number to put down.
now to find money for a new clutch pinch.gif ( or not do hard launches )
car won't be ready fellas, but i will be there spectating and taking some happy snaps.
whens the next one due after this?
All the club events are listed in the 2012 events thread, link is above in the last post of mine
Yes shouldve, we can sort that on the day worst case
This event is now on the clubs facebook page, click the link and share with your friends please! Without people coming to these events the club wont put them on :)
http://www.facebook.com/events/148447388602927/
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
