Shamelessly stolen from Stevo.
Hey guys and gals!
You all know the drill, this thread means entries for Texi, February 12th, are now open :)
Event: SAUNSW Texikhana, S.O.S. proudly supported by Unigroup Engineering
Location: Nirimba Airfield/Tafe/Skidpan/same place as last time (yeah its got a few names)
Location map: Click HERE :D
Date: 12th February 2012
What is it: Skidpan + Go-to-whoa
Lunch: BBQ and cans of soft drink available on site
Spectators: Free to watch, BBQ will be $3 snag sandwich and $1.50 cans (selection of flavours available)
Passengers: Free, MUST sign on, wear wrist to neck/ankle clothing with enclosed shoes and approved helmet same as drivers
Courses: Released on the day at sign on
First timers: Don't be shy, you'll love it. First timer F.A.Q. (Thanks Owen) available HERE (Click me baby)
Those of you that have been to one of these before will agree, this is the best money you can spend as far as driving time for an event. The event will be run after run until 430pm, and considering most runs are under 1 minute AND that we're kicking off at 9am, thats a lot of runs ;)
This is a safe event where you only go as hard as you want to, there's no pressure, one car on a course at a time. Perfect for beginners to have a first try at driving their pride and joy off the streets.
With that said, there's usually some friendly competition between mates which is great to watch :)
Timing for the day;
Scruitineering/sign on starts 7am
Scruitineering/sign on ends 830am (dont show up at 825am, come with plenty of time to spare)
Drivers brief 840am (mandatory attendance all drivers)
Runs start 9am
Lunch approx 1230pm depending on how the day is going (One hour)
Runs stop 445pm
Gates close 5pm
Entrants please note:
-All entered cars must arrive in time for and pass scruitineering, no exceptions.
-All drivers must be licensed (AASA or CAMS) and show valid licence and expiry date at sign on.
-All cars must have an insurance approved fire extinguisher secured within drivers reach.
-Sidepipes are not allowed. Screamers/external gates venting to atmosphere are also not allowed to be entered. No exceptions (this is not my choice, I ♥ gate)
-Entries are open now, entries close 5pm 10th February to allow time for officials to organise paperwork.
-Supp regs and Entry Form are attached. Entry forms without payment will be rejected.
-Yes you can join SAUNSW on the day (allow an extra 5mins at sign on)
-Yes you can organise an AASA or CAMS licence on the day (allow extra 10mins at sign on)
-There is no Eftpos/Credit Card machine on site, so bring cash and we will have change there for you. If you can bring close to the right amount that's helpful.
SAUNSW bank details:
Bank - NAB
Branch - Marrickville
Account name - Skylines Australia NSW
BSB - 082 356
Account number - 546 393 766
Please put your FULL NAME in the description, eg "TEXI JOE SMITH"
Dont wait until the night before to enter. These events sell out, to avoid disappointment get onto it right now - you've been warned ;)
See you at the skidpan
-Stevo
Come along guys.
These days are awesome fun, Please check the NSW Events section for any additional details and entry forms.
https://www.sau.com.au/forums/topic/383736-saunsw-texi-sos-12th-feburary-2012/
THAT'S MY BIRTHDAY!!! :cheers::merli: <- it's a party hat k...
I need to be in Sydney near quakers hill that night anyway as that is where my course accommodation is... Hmmmmmm, interesting :D
*Stares in Zane's direction* Please, It's my birthday so I'll be happy... Texi... Do it...??? :wub:
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
