*adelaide* R33 Gts-T 9K
1993 R33 Gts-t for sale
156xxx K's on the shell on the car
was resprayed the same burgundy colour about 2 months ago
has a s2 rb25det that is about 6000 Ks past its 100000km service (done late last year)
i bought the car early this year and it was my first import so i looked after it and loved it, cleaned every week (especially after respray sometimes even twice)
but the time has come to finally upgrade to a gtr as ive been offered one from a mate that i dont want to pass up.
i run stock boost (7 psi) which makes 168kw dyno sheet to prove
have old dyno from previous owner for 11 psi which was 198 kw
always warmed up for a good 5 minutes and cooled down with an apexi turbo timer.
i have many many receipts for body work and exhaust work
when i bought it the car had a veilside bodykit but i changed it to a s2 front bar with the rest s1 stock gear, all needed a spray so i got the whole car done.
still have veilside to go with car if wanted.
receipts for other things like s2 steering wheel
nismo indicators
dump pipe
high flow cat
and the kit which included s2 front bar
side skirts
rear pods
s1 grill
etc
has an xforce cat back exhaust with electronic varex tip
have old 4inch exhaust to go with it which was a straight through exhaust (very loud) i liked it but it attracted to much attention so i got the electronic exhaust done
other specs of the car
lowered (not sure of springs or brands or anything...)
18 inch ROH rims
splitfire coilpacks
TRUST FMIC and pod filter
recaro seats
flush dash mounted boost gauge
pioneer stereo with sub and amp
gtr rear spoiler
immobiliser
other details which i have no doubt forgotten
old owner had the big service done just before i bought it
i have a few receipts for some of the work but not all so youll have to take my word for some of this stuff
new kyb rear shocks
turbo gaskets
brake pads
new belts inc. timing belt
wheel alignment
new tyres (still got loads of tread)
new battery
and other bits and pieces...
only has 2 minor imperfections which are - power window is dicky, needs a new relay. trying to chase one up but they are worth bugger all.
and the s1 grill isnt attached because the RHS lights clips are broken off (dont know how)
the car owes me over 16 grand just from the last year, selling at my loss but i am willing to bite the bullet to get a gtr.
car has never given me any mechanical problems all my money was spent to make it look better whilst also being legal.
the car isnt my daily driver and is locked away in a garage and i have only been taking it out on weekends (sometimes not at all)
just put 3 months rego on the car.
0421549607
text during day.
call or text after 5pm.
sean.
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
