Yeah, I like the body styling, altho interior I suspect will be as bland as other Toyotas... Unless someone recolour some trim parts with other colours like silver or woodgrain... depends on which style they want..
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62323
Originally posted by skyzerr33
nope
the orignal version of that engine (mk3 supra and soarer) had the twin turbo's. in later model cars ie the jzx100 they dropped the two small turbos for a single larger one. its more responsive and less laggy aparently.
then, how come all the jzx100s listed at j-spec auction data are twin turbos???
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62661
I think the single turbos were pretty dam rare. The 92 supras had singles and they got vvTi as well. Most of the 1jz's out there are twins dunno why maybe they started concerntrating on the 3.0 2jz and gave up on the old tech.
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62685
Even on some supra lots of ppl modify them into a single turbo conversion, as it is far cheaper than buying two sets of turbo and a good single turbo will do the job well.
Alternatively, I think it won't be long until someone stick in a twin turbo charged 2JZGTE engine from a Supra into a Chaser JZX100... Dunno if that can be achieved as gearbox mount, driveshaft length etc could be different. But the engine bay suppose to fit as it looks larger than a Supra.
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62692
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
    • Not sure why but RBF660/700 or Castrol SRF is listed as DOT4, not 5.1.
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
